[GRASS5] grass5.3.0 compilation
Dear all...
I'm trying to compile grass 5.3.0 on a debian testing
with this options:
./configure --with-tcltk-includes=/usr/include/tcl8.3
--with-postgres-includes=/usr/include/postgresql/
--with-opengl-includes=/usr/include/GL --with-dbm --with-proj
--with-gdal --with-jpeg=no --with-png=no --with-odbc=no --with-fftw=no
at the and of the make process I obtain this answer:
GRASS GIS source code compiled.
Compilation error in module: src/imagery/i.ortho.photo (ignored)
Compilation error in module: src/imagery/i.rectify2 (ignored)
Compilation error in module: src/mapdev/v.digit (ignored)
Compilation error in module: src/mapdev/v.spag (ignored)
Compilation error in module: src/raster/r.in.png (ignored)
Compilation error in module: src/raster/r.mapcalc3 (ignored)
Compilation error in module: src/raster/r.out.png (ignored)
Compilation error in module: src.contrib/GMSL/NVIZ2.2 (ignored)
no problem for r.in.png but what about the other errors??
during the compilation of the previous source snapshot I apparently
didn't obtain errors...
can you give me some help???
thank you very much!!!!
ivan
with this options:
We need to see the actual error messages from the output from "make".
Dear all and dear Glynn,
I reassume my problem....:
_________________________________________________________
with this options:
I attach some of the errors messages taken from the make output!!!!
Thank you very much!!!!!!!!
Ivan
(Attachment i.ortho.photo is missing)
(Attachment nviz is missing)
(Attachment v.digit is missing)
(Attachment v.spag is missing)
with this options:
/home/ivan/Documents/GRASS/grass53_exp_2004_05_15/src/imagery/i.ortho.photo/photo.rectify
  make -f OBJ.i686-pc-linux-gnu/make.rules
make[2]: Entering directory `/home/ivan/Documents/GRASS/grass53_exp_2004_05_15/src/imagery/i.ortho.photo/photo.rectify'
gcc -I../libes -L/home/ivan/Documents/GRASS/grass53_exp_2004_05_15/src/libes/LIB.i686-pc-linux-gnu -Wl,--export-dynamic -o /home/ivan/Documents/GRASS/grass53_exp_2004_05_15/dist.i686-pc-linux-gnu/etc/imagery/photo.rectify OBJ.i686-pc-linux-gnu/main.o OBJ.i686-pc-linux-gnu/ask_files.o OBJ.i686-pc-linux-gnu/ask_files2.o OBJ.i686-pc-linux-gnu/ask_wind.o OBJ.i686-pc-linux-gnu/ask_elev.o OBJ.i686-pc-linux-gnu/get_wind.o OBJ.i686-pc-linux-gnu/aver_z.o OBJ.i686-pc-linux-gnu/cp.o OBJ.i686-pc-linux-gnu/ps_cp.o OBJ.i686-pc-linux-gnu/compress.o OBJ.i686-pc-linux-gnu/conv.o OBJ.i686-pc-linux-gnu/env.o OBJ.i686-pc-linux-gnu/exec.o OBJ.i686-pc-linux-gnu/equ.o OBJ.i686-pc-linux-gnu/mail.o OBJ.i686-pc-linux-gnu/matrix.o OBJ.i686-pc-linux-gnu/perform.o OBJ.i686-pc-linux-gnu/rectify.o OBJ.i686-pc-linux-gnu/report.o OBJ.i686-pc-linux-gnu/target.o OBJ.i686-pc-linux-gnu/write.o ../libes/LIB.i686-pc-linux-gnu/libortho.a -lI -lgis -lD -ldisplay -lraster -lsegment -lvask -lgmath -lncurses -lbsd-compat -lm -lz
/usr/local/lib/libz.a(compress.o)(.text+0xb0): In function `compress':
: multiple definition of `compress'
OBJ.i686-pc-linux-gnu/compress.o(.text+0x0):/home/ivan/Documents/GRASS/grass53_exp_2004_05_15/src/imagery/i.ortho.photo/photo.rectify/compress.c:5: first defined here
/usr/bin/ld: Warning: size of symbol `compress' changed from 7 in OBJ.i686-pc-linux-gnu/compress.o to 177 in /usr/local/lib/libz.a(compress.o)
collect2: ld returned 1 exit status
It seems that your linker doesn't like symbols which are exported from
both an object file and a static library. It may be because it's using
the static library /usr/local/lib/libz.a rather than the system's
default shared libz.so.
You could try moving or renaming /usr/local/lib/libz.a while building
GRASS.
Note: v.digit and v.spag both fail for the same reason, so anything
which works for photo.rectify should also work for those.
/home/ivan/Documents/GRASS/grass53_exp_2004_05_15/src.contrib/GMSL/NVIZ2.2/src
make[2]: Entering directory `/home/ivan/Documents/GRASS/grass53_exp_2004_05_15/src.contrib/GMSL/NVIZ2.2/src'
gcc -I/home/ivan/Documents/GRASS/grass53_exp_2004_05_15/src/include -g -O2 -I/usr/X11R6/include -I/usr/include/tcl8.3 -I/usr/include/tcl8.3 -I/home/ivan/Documents/GRASS/grass53_exp_2004_05_15/src/libes/ogsf -D_NO_PROTO -D__STDC__ -I/usr/include/postgresql/ -c togl.c -o OBJ.i686-pc-linux-gnu/togl.o
<command line>:5:1: warning: "__STDC__" redefined
togl.c:38:66: X11/Xmu/StdCmap.h: No such file or directory
X11/Xmu/StdCmap.h is a standard X11 header. Are you using a cut-down
version of X11? Or is this just the latest incompatible change from
the XFree86 people?
Also, I don't see anything related to the r.mapcalc error. That is
significantly more important than the other errors; I would appreciate
any information which you can provide.
Dear Glynn and dear all,
thank you very much for your answer...
I apologize for the delay of my answer... but I have been out of the
office for a long period...
about the compilation errors I said you some days ago....:
I have made these steps:
mv /usr/local/lib/libz.a /usr/local/lib/libz.a-bak
ln -s /usr/lib/libz.so.1 /usr/local/lib/libz.a
then I tried to compile and a lot of errors I obtained before were
removed, I only obtained:
now: since I compiled without png support (with-png=no) the only problem
remains NVIZ...
during your last e-mail, you asked about the version of XFree I'm
using... it is the 4.3.0.dfsg.1-1
this is the error I still obtain:
__________________________________________________________________
/home/ivan/Documents/GRASS/grass-5.3.0/src.contrib/GMSL/NVIZ2.2/src
  mkdir OBJ.i686-pc-linux-gnu
`/home/ivan/Documents/GRASS/grass-5.3.0/src.contrib/GMSL/NVIZ2.2/src'
gcc -I/home/ivan/Documents/GRASS/grass-5.3.0/src/include -g -O2
-I/usr/X11R6/include -I/usr/include/tcl8.3 -I/usr/include/tc$
init_commands.c: In function `init_commands':
init_commands.c:152: warning: passing arg 3 of `Tcl_CreateCommand' from
incompatible pointer type
init_commands.c:154: warning: passing arg 3 of `Tcl_CreateCommand' from
init_commands.c:166: warning: passing arg 3 of `Tcl_CreateCommand' from
init_commands.c:169: warning: passing arg 3 of `Tcl_CreateCommand' from
init_commands.c:173: warning: passing arg 3 of `Tcl_CreateCommand' from
init_commands.c:175: warning: passing arg 3 of `Tcl_CreateCommand' from
init_commands.c:177: warning: passing arg 3 of `Tcl_CreateCommand' from
init_commands.c:179: warning: passing arg 3 of `Tcl_CreateCommand' from
init_commands.c:180: warning: passing arg 3 of `Tcl_CreateCommand' from
init_commands.c:182: warning: passing arg 3 of `Tcl_CreateCommand' from
init_commands.c:184: warning: passing arg 3 of `Tcl_CreateCommand' from
init_commands.c:187: warning: passing arg 3 of `Tcl_CreateCommand' from
init_commands.c:189: warning: passing arg 3 of `Tcl_CreateCommand' from
init_commands.c:190: warning: passing arg 3 of `Tcl_CreateCommand' from
init_commands.c:191: warning: passing arg 3 of `Tcl_CreateCommand' from
init_commands.c:193: warning: passing arg 3 of `Tcl_CreateCommand' from
init_commands.c:194: warning: passing arg 3 of `Tcl_CreateCommand' from
init_commands.c:195: warning: passing arg 3 of `Tcl_CreateCommand' from
init_commands.c:196: warning: passing arg 3 of `Tcl_CreateCommand' from
init_commands.c:198: warning: passing arg 3 of `Tcl_CreateCommand' from
init_commands.c:200: warning: passing arg 3 of `Tcl_CreateCommand' from
init_commands.c:201: warning: passing arg 3 of `Tcl_CreateCommand' from
init_commands.c:203: warning: passing arg 3 of `Tcl_CreateCommand' from
init_commands.c:204: warning: passing arg 3 of `Tcl_CreateCommand' from
init_commands.c:205: warning: passing arg 3 of `Tcl_CreateCommand' from
init_commands.c:333: warning: passing arg 3 of `Tcl_CreateCommand' from
make[2]: *** [OBJ.i686-pc-linux-gnu/togl.o] Error 1
make[2]: Leaving directory
make[1]: *** [nvwish] Error 2
make[1]: Leaving directory
`/home/ivan/Documents/GRASS/grass-5.3.0/src.contrib/GMSL/NVIZ2.2'
GISGEN failure at STEP: src.contrib/GMSL/NVIZ2.2
What do you think about this error???
thank you very much for your answer....
Ivan
> with this options:
GRASS.
the XFree86 people?
That last one isn't right. Ideally, there shouldn't be a libz.a
anywhere, and there shouldn't be libz.<anything> in /usr/local/lib,
there should just be something like the following in /usr/lib:
lrwxrwxrwx 1 root root 13 Apr 2 2002 /usr/lib/libz.so -> libz.so.1.1.3
lrwxrwxrwx 1 root root 13 Apr 2 2002 /usr/lib/libz.so.1 -> libz.so.1.1.3
-rwxr-xr-x 1 root root 59655 Feb 25 2002 /usr/lib/libz.so.1.1.3
However, your existing problems don't appear to be related to zlib.
remains NVIZ...
Well, the standard XFree86 4.3.0 release includes X11/Xmu/StdCmap.h,
so it appears that whoever built the package which you are using has
removed it, or at least moved it to a separate package. You will have
to ask the package maintainer about this issue.
> remains NVIZ...
see here for needed Debian packages to compile GRASS:
http://article.gmane.org/gmane.comp.gis.grass.user/4788
This is provided by the "libxmu-dev" debian package.
('apt-file search X11/Xmu/StdCmap.h')
Hamish
Thank you to all....
I will try to do all you said....
Ivan
> > remains NVIZ...
Hamish
grass5 mailing list
grass5@grass.itc.it
http://grass.itc.it/mailman/listinfo/grass5
Hi hamish..., hi to all...
I installed om my debian testing the libxmu-dev and also the tk8.3-dev
and now the compilation is perfect!!!!
Thank you very much to all...
ivan
> > remains NVIZ...
Hamish
grass5 mailing list
grass5@grass.itc.it
