[GRASS5] GRASS5.7: pg.postgisdb path to libgis partially hard-coded
Hello,
Trying to use pg.postgisdb, I realised that part of the path to postgis is
hard-coded:
when I give the option '-P /usr/lib/postgresql' I get
libpostgis.so.x.x dir: '/usr/lib/postgresql/lib/contrib/
In the pg.postgisdb script this seems to be defined at line 176:
libpostgisdir="$postgis/lib/contrib/"
However, I have the postgis library installed directly in
/usr/lib/postgresql/lib/ without a contrib directory. In order to use the
module, I had to create a directory contrib and symlink from that
directory back to the library file.
Is there any reason to suppose the existance of any specific directories ?
Moritz
On Thursday 04 December 2003 19:05, Moritz Lennert wrote:
Hello,
hard-coded:
I have (Postgres 7.1.3):
....../pgsql/lib/contrib/libpostgis.so.0.6
maybe the place has changed. I think that pg.postgisdb has potentialy
more problems, and it doesn't do anything GRASS specific except
'--sheep' option. Shall I remove it?
Radim
Hello,
is
hard-coded:
the
I don't understand its value, yet (I was just blindly following the
tutorial), so I can't comment on that, but if you decide to keep it, it
should not expect any specific locations.
Moritz
On Fri, Dec 05, 2003 at 05:34:44PM +0100, Moritz Lennert wrote:
>> Hello,
>> is
>> hard-coded:
>> the
tutorial),
[that's probably no good idea :slight_smile: The tutorial is more written task oriented
than to use top-bottom ]
The question is if all Linux (whatever) distros follow the same directory
layout.
