[GRASS5] GRASS5.7: trouble converting shapefile to postgis with v.convert
Hello,
I have a shapefile registered in GRASS5.7:
GRASS 5.7.-cvs:~ > g.list vect
vector files available in mapset mlennert:
communes.shp
I can display and query this file without any problems.
It is connected to a dbf file:
GRASS 5.7.-cvs:~ > v.db.connect -p communes.shp
Vector map <communes.shp> is connected by:
field <1> table <communes> in database </home/mlennert/SHAPEFILES/>
through driver <shp> with key <shp_fid>
Following the tutorial, I tried to store this map in PostGIS format:
GRASS 5.7.-cvs:~ > v.database driver=pg database="dbname=digit_belgium"
GRASS 5.7.-cvs:~ > v.convert input=communes.shp output=communes
but I got the error message: "ERROR: Input vector was not found."
What am I doing wrong ?
Moritz
On Thursday 04 December 2003 19:17, Moritz Lennert wrote:
Hello,
communes.shp
v.convert converts old GRASS vector files (GRASS 4.0,5.0) to 5.1/7 format.
v.database is used to set the database for attributes.
If you want to write a vector in PostGIS format, you have first set
the output vector format to PostGIS either in
v.format -> output format -> PostGIS
or by g.gisenv:
g.gisenv store=mapset set=GV_FORMAT=POSTGIS
g.gisenv store=mapset set=GV_PGIS_DATABASE=host=liptakov,dbname=cimrman,user=jara
Once you set vector format to PostGIS, all new vectors are written to the database.
Attributes are by default written to dbf files, so until you set also
you get geometry in Postgres and attributes in dbf, isn't it funny?
To convert the vector you can run g.copy for example, but that is not what you want
as communes will be polygons and you have to clean such vector first.
I would recommend v.in.ogr as it does all the cleaning. See the statistics about
areas at the end.
Radim
Hello,
communes.shp
field <1> table <communes> in database </home>
or by g.gisenv:
database.
I did all these steps, just following the tutorial, but the problem was
the usage of v.convert. May I conclude that the description in the
tutorial at
http://grass.itc.it/grass51/tutorial/geom_storage.html#PostGRASS is wrong
then ?
you want
about
areas at the end.
So you would recommend this rather than just using the shp2pgsql program
that comes with postgis ?
Moritz
On Fri, Dec 05, 2003 at 05:38:44PM +0100, Moritz Lennert wrote:
>> Hello,
>> communes.shp
> or by g.gisenv:
> database.
tutorial at
then ?
Possibly yes. The tutorial *tries* to keep pace with the 5.7 development.
But that's not always possible due to (my) time constraints.
Sorry for any inconvenience, I am happy to receive corrections.
> you want
> about
> areas at the end.
Note that areas are treated differently in PostGIS and PostGRASS (the latter
with pseudo-topology, correct me if I am wrong). So it will work only for
lines and points.
