[GRASS5] grass5 beta11 pre2
had a run with the beta11 pre2 at the weekend, found only one problem, but most
likely related to my VoodooII. Starting NViz switches the display to full
screen, I can see the raster I selected, but that's it. But as I say, I think
it is the Voodoo.
Otherwise nothing found so far...
Arne
P.S.: Anything special that has to be tested??
Arne Pallentin
Department of Earth Sciences
The University of Waikato
Private Bag 3105
Hamilton - New Zealand
Ph.: +64-7-838 4024 ext. 6229
Home: +64-7-856 7877
Fax. +64-7-856 0115
e-mail: arne@waikato.ac.nz
subject 'unsubscribe grass5'
Hi Arne,
On Sun, Feb 04, 2001 at 05:36:15PM +1300, Arne Pallentin wrote:
it is the Voodoo.
seems to be like that as I never got such a problem on various platforms.
Great.
Arne
Does the graphical window open properly while starting GRASS?
If you have switched off this in past, re-enable with (once only):
grass5 -tcltk
Otherwise I will tag "beta11" later this day and build the binaries
for Linux.
Thanks for testing,
