[GRASS5] grass51/debian/rules
re this change:
http://grass.itc.it/pipermail/grass-commit/2004-November/015869.html
- --with-gdal=/usr/bin/gdal-config \
+ --with-gdal=/usr/local/bin/gdal-config \
$ dpkg -L libgdal1-dev | grep gdal-config
/usr/share/man/man1/gdal-config.1.gz
??? shouldn't it just be --with-gdal? Isn't that redundant now, omit
altogether?
+ --without-odbc
The unixodbc-dev package is in the control file's "Build-Depends" list,
why not use it?
Hamish
On Tue, Nov 30, 2004 at 05:51:55PM +1300, Hamish wrote:
re this change:
altogether?
+ --without-odbc
why not use it?
Hamish,
please apply fixes right away since you have a Debian distro running.
Thanks
Markus Neteler <neteler itc it> http://mpa.itc.it
ITC-irst - Centro per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18 - 38050 Povo (Trento), Italy
