[GRASS5] grass51: value of $(GDALLIBS) in a Makefile
I noticed this when compilation got to v.out.ogr, it compained about
unresolved OGR* symbols. This is due to wrong definition of GDALLIBS in
Platform.make -- here's what it has:
gdal
GDALLIBS = -ldl
After fixing it to:
GDALLIBS = -lgdal
everything worked ok. Unfortunately I don't know enough about Makefile.in
stuff to see how this was generated
Aleksey
Aleksey Naumov
GIS Analyst
Center for Health and Social Research
Buffalo State College
On Sat, 14 Jun 2003, Aleksey Naumov wrote:
You need to use the --with-gdal option with the configure script. I will
look at making this the default for 5.1
Paul
I am having the similar problem in v.in.ogr (even with -with-gdal option):
make[2]: Entering directory `/home/grass/grass51_exp_2003_06_07/vector/v.in.ogr'
    main.c: In function `main':
    main.c:142: `wkbLinearRing' undeclared (first use in this function)
    main.c:142: (Each undeclared identifier is reported only once
    main.c:142: for each function it appears in.)
    main.c:52: warning: `Ogr_layer' might be used uninitialized in this function
    main.c: At top level:
    /home/grass/grass51_exp_2003_06_07/include/gis.h:36: warning: `GRASS_copyright' defined but not used
    make[2]: *** [OBJ.i686-pc-linux-gnu/main.o] Error 1
    make[2]: Leaving directory `/home/grass/grass51_exp_2003_06_07/vector/v.in.ogr'
    make[1]: *** [subdirs] Error 1
    make[1]: Leaving directory `/home/grass/grass51_exp_2003_06_07/vector'
    make: *** [default] Error 1
Moreover, v.out.ogr compiled OK but it doesn't work:
GRASS 5.1.0-cvs:~ > v.out.ogr
v.out.ogr: error while loading shared libraries: libgdal.1.1.so: cannot open shared object file: No such file or directory
Jaro
Paul
grass5 mailing list
grass5@grass.itc.it
http://grass.itc.it/mailman/listinfo/grass5
Yaro,
Is your libgdal.1.1.so in the library search path (in $LD_LIBRARY_PATH or
directory where it is listed in /etc/ld.so.conf (then you also have to do
/sbin/ldconfig))? I also had to add a link to my libgdal.1.1.so:
libgdal.so -> libgdal.1.1.so, in order for the -lgdal linking flag to work.
Aleksey
On Sunday 15 June 2003 03:02 pm, Jaro Hofierka wrote:
function
Jaro
>>Hi,
> Paul
> grass5 mailing list
> grass5@grass.itc.it
grass5 mailing list
grass5@grass.itc.it
Aleksey Naumov
GIS Analyst
Hi Aleksey,
Thanks for hints regarding ld.co.conf,ldconfig and linking libgdal.so to libgdal.1.1.so. Now the modules run with no problem.
Jaro
I noticed this when compilation got to v.out.ogr, it compained about unresolved OGR* symbols. This is due to wrong definition of GDALLIBS in Platform.make -- here's what it has:
gdal
GDALLIBS = -ldl
After fixing it to:
GDALLIBS = -lgdal
everything worked ok. Unfortunately I don't know enough about Makefile.in stuff to see how this was generated
Aleksey
On Sunday 15 June 2003 21:02, Jaro Hofierka wrote:
wkbLinearRing is 'new' in OGR, I wanted to change it to wkbLineString which
I hope could work. But I was not able to compile OGR without OGDI and I could not
get compiled OGDI, so I have not submited this yet.
Radim
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
which
I could not
BTW, this means that you need a recent cvs snapshot of gdal to build
these, it would be nice if this could be noted somewhere ...
Buchan
|--------------Another happy Mandrake Club member--------------|
Buchan Milne Mechanical Engineer, Network Manager
Cellphone * Work +27 82 472 2231 * +27 21 8828820x202
Stellenbosch Automotive Engineering http://www.cae.co.za
GPG Key http://ranger.dnsalias.com/bgmilne.asc
1024D/60D204A7 2919 E232 5610 A038 87B1 72D6 AC92 BA50 60D2 04A7
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.2.2 (GNU/Linux)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
iD8DBQE+7vzcrJK6UGDSBKcRAghUAJ0QpxF2N5Elgw5hi1a1z5tdUbpTVACdEa/a
EFJZzyp+TC7cKSN4QfVyTmI=
=602f
-----END PGP SIGNATURE-----
Please click on http://www.cae.co.za/disclaimer.htm to read our
e-mail disclaimer or send an e-mail to info@cae.co.za for a copy.
