[GRASS5] GRASS57: debian package build : dead symbolic links to 5.3 sources
Hello,
I am trying to use dpkg-buildpackage on 5.7. However, I have the following
problem:
in debian/rules the following defines the location of the 5.3 sources:
GRASS53SRC=../grass-5.3.0
this is correct for me as I have:
$ ls -l
total 20
drwxr-xr-x 23 mlennert mlennert 4096 2004-01-05 15:40 grass
drwxr-xr-x 21 mlennert mlennert 4096 2004-01-27 16:10 grass51
lrwxrwxrwx 1 mlennert mlennert 5 2004-01-27 15:24 grass-5.3.0 ->
grass
lrwxrwxrwx 1 mlennert mlennert 7 2004-01-27 15:24 grass-5.7.0 ->
grass51
However, in grass-5.7.0/include I have a series of dead links pointing to
../grass-5.3.0/src/include/*.h
This should be ../../grass-5.3.0/src/include/*.h
Where can I change the links that are created ?
Moritz
On Tue, Jan 27, 2004 at 04:25:10PM +0100, Moritz Lennert wrote:
Hello,
problem:
$ ls -l
total 20
grass
grass51
In grass51/debian/rules you find the configuration. It seems,
that
- the link trick above doesn't work with 'make mix' done in
- something else not right.
Did you try to rename the dirs instead of linking?
Once we were able to make a debian package, if time, I'll
try again soon.
Hello,
problem:
$ ls -l
total 20
grass
grass51
that
I did and it doesn't work either, i.e. the links in grass-5.7.0/include
are again to ../grass-5.3.0 and not to ../../grass-5.3.0.
I solved the problem by replacing the relative path for
#path to GRASS 5.3 source code
GRASS53SRC=
to an absolute path.
Moritz
>> Hello,
>> problem:
>> $ ls -l
>> total 20
>> grass
>> grass51
> that
GRASS53SRC=
Ah, now I understand: Maybe it depends in which directory you
launch 'dpkg-buildpackage'
Do you think I should change it to an absolute path?
>> Hello,
following
>> problem:
sources:
>> $ ls -l
>> total 20
>> grass
grass-5.7.0 ->
>> grass51
pointing to
> that
GRASS53SRC=
I thought that you always have to launch it in the directory in which
there is a debian/ subdirectory ?
The absolute path will be different for everyone, so I don't know how this
could be done without manual intervention. Maybe a hint in a README.Debian
would be better ?
Moritz
>> >> Hello,
>> GRASS53SRC=
Yes, at least that is what I was doing (and it worked).
would be better ?
Someone else (debian developer) recommended
mkdir /usr/src/grass/
cd /usr/src/grass/
to me. This path is now hardcoded in debian/rules.
If following the instructions, it should be fine now.
[Yes, it's not convenient, yes, code should be merged (but not downgraded)].
>> >> Hello,
>> GRASS53SRC=
this
README.Debian
would be better ?
cd /usr/src/grass/
I suppose this means that I should either link to the CVS tree from
/usr/src/grass or actually move the tree to there.
It works, the only disadvantage being that you need root access to use
/usr/src/grass.
Moritz
>> >> >> Hello,
>> >> GRASS53SRC=
>> this
>> README.Debian
>> would be better ?
> cd /usr/src/grass/
Yes, I think so.
/usr/src/grass.
Since I have low experience with Debian, please give advice how to
find a better solution.
Up to now it was "proof of concept" (and we needed an iPAQ version of 5.7).
