Hello,
Working in a latlon dataset I noticed that v.label's size 1 (range
1-1000) produces huge ps.map labels in small areas (since label's size is in map
units).
Changing the type from TYPE_INTEGER to TYPE_DOUBLE all works flawlessy
and I'm able to give e.g. 0.1 as label size that output correctly in
ps.map output.
Here's the cvs diff:
Index: main.c
RCS file: /home/grass/grassrepository/grass51/vector/v.label/main.c,v
retrieving revision 1.2
diff -r1.2 main.c
111c111
< Size->type = TYPE_INTEGER;
Size->type = TYPE_DOUBLE;
113c113
< Size->options = "1-1000";
/*Size->options = "1-1000";*/
Hope it helps.
Alessandro
Alessandro Frigeri
echo '>ti.liame@iregirfa<' | rev
