Greetings listers,
The following modules:
/usr/src/grass/src/display/d.colors
/usr/src/grass/src/imagery/i.class
/usr/src/grass/src/imagery/i.ortho.photo/photo.2image
/usr/src/grass/src/imagery/i.points
/usr/src/grass/src/imagery/i.points3/inter
/usr/src/grass/src/imagery/i.vpoints
Report the same error:
/usr/bin/ld: Undefined symbols:
_gtty
_stty
Any ideas??
Jeshua Lacock
Cartographer/Owner
http://SierraMaps.com
http://3dTopoMaps.com
Telephone: (760) 935-4481
subject 'unsubscribe grass5'
On Tue, Dec 05, 2000 at 04:07:11PM -0800, Jeshua Lacock wrote:
Greetings listers,
_gtty
_stty
Those should be defined in libncurses, I think. Do you have the
ncurses5 library installed? It may be the linker is not finding the
libraries correctly (maybe use the --with-libs=/path/to/libdir). The
linker is often very limited in where it will look for thing by default,
hence all the -L/usr/X11R6/lib and similar flags. See other post as
well.
Eric G. Miller <egm2@jps.net>
