[GRASS5] _gtty & _stty errors
On Tuesday, December 5, 2000, at 10:54 PM, Eric G . Miller wrote:
On Tue, Dec 05, 2000 at 04:07:11PM -0800, Jeshua Lacock wrote:
> Greetings listers,
> The following modules:
> /usr/src/grass/src/display/d.colors
> /usr/src/grass/src/imagery/i.class
> /usr/src/grass/src/imagery/i.ortho.photo/photo.2image
> /usr/src/grass/src/imagery/i.points
> /usr/src/grass/src/imagery/i.points3/inter
> /usr/src/grass/src/imagery/i.vpoints
> Report the same error:
> /usr/bin/ld: Undefined symbols:
> _gtty
> _stty
Those should be defined in libncurses, I think. Do you have the
ncurses5 library installed? It may be the linker is not finding the
libraries correctly (maybe use the --with-libs=/path/to/libdir). The
linker is often very limited in where it will look for thing by default,
hence all the -L/usr/X11R6/lib and similar flags. See other post as
well.
Thanks Eric,
To my knowledge, I do not have ncurses5. I just searched on the web for it and I could not locate it. Do you know where I may locate it?
Jeshua Lacock
Cartographer/Owner
http://SierraMaps.com
http://3dTopoMaps.com
Telephone: (760) 935-4481
subject 'unsubscribe grass5'
http://www.gnu.org/software/ncurses/ncurses.html
http://freshmeat.net/projects/ncurses
Professional Service around Free Software (intevation.net)
The FreeGIS Project (freegis.org)
FSF Europe (www.fsfeurope.org)
