[GRASS5] _gtty & _stty errors
On Tuesday, December 5, 2000, at 10:54 PM, Eric G . Miller wrote:
On Tue, Dec 05, 2000 at 04:07:11PM -0800, Jeshua Lacock wrote:
> Greetings listers,
> The following modules:
> /usr/src/grass/src/display/d.colors
> /usr/src/grass/src/imagery/i.class
> /usr/src/grass/src/imagery/i.ortho.photo/photo.2image
> /usr/src/grass/src/imagery/i.points
> /usr/src/grass/src/imagery/i.points3/inter
> /usr/src/grass/src/imagery/i.vpoints
> Report the same error:
> /usr/bin/ld: Undefined symbols:
> _gtty
> _stty
Those should be defined in libncurses, I think. Do you have the
ncurses5 library installed? It may be the linker is not finding the
libraries correctly (maybe use the --with-libs=/path/to/libdir). The
linker is often very limited in where it will look for thing by default,
hence all the -L/usr/X11R6/lib and similar flags. See other post as
well.
Hi gang,
Ok, I installed the libncurses 5.2 and it appears that they were already installed because modules that compiled before gave a error stating that "/usr/lib/libncurses.a is out of date; rerun ranlib(1)". After updating with ranlib the modules that worked before now work, however, I still get the errors with the above modules:
   _gtty
   _stty
Which leads me to believe that they must be defined somewhere else.... Where??
I would really like to figure this one out as it will fix 6 modules....
Jeshua Lacock
Cartographer/Owner
http://SierraMaps.com
http://3dTopoMaps.com
Telephone: (760) 935-4481
subject 'unsubscribe grass5'
> > _gtty
> > _stty
> well.
Hi gang,
   _gtty
   _stty
Well, not sure where those get defined, but I find "gtty" and "stty" in
libc.a. I couldn't find those symbols in libncurses.a, libcurses.a, or
libtermcap.a -- sorry for the red herring. You can use "nm
/path/to/staticlib.a | grep '<symbol>'" to hunt for where symbols are
defined. See if libc.a has 'stty' (it probably does). Are you using
the --with-USE_TERMIO directive? If not, maybe it's worth a try.
Eric G. Miller <egm2@jps.net>
