On Wednesday, December 6, 2000, at 06:10 PM, Eric G . Miller wrote:
On Wed, Dec 06, 2000 at 03:31:57PM -0800, Jeshua Lacock wrote:
> > > Report the same error:
> > > /usr/bin/ld: Undefined symbols:
> > > _gtty
> > > _stty
> > Those should be defined in libncurses, I think. Do you have the
> > ncurses5 library installed? It may be the linker is not finding the
> > libraries correctly (maybe use the --with-libs=/path/to/libdir). The
> > linker is often very limited in where it will look for thing by default,
> > hence all the -L/usr/X11R6/lib and similar flags. See other post as
> > well.
> Hi gang,
> Ok, I installed the libncurses 5.2 and it appears that they were already installed
because modules that compiled before gave a error stating that
"/usr/lib/libncurses.a is out of date; rerun ranlib(1)". After updating with ranlib
the modules that worked before now work, however, I still get the errors with the above
modules:
> _gtty
> _stty
> Which leads me to believe that they must be defined somewhere else.... Where??
> I would really like to figure this one out as it will fix 6 modules....Well, not sure where those get defined, but I find "gtty" and "stty" in
libc.a. I couldn't find those symbols in libncurses.a, libcurses.a, or
libtermcap.a -- sorry for the red herring. You can use "nm
/path/to/staticlib.a | grep '<symbol>'" to hunt for where symbols are
defined. See if libc.a has 'stty' (it probably does). Are you using
the --with-USE_TERMIO directive? If not, maybe it's worth a try.--
Hi Eric,
Where would use the "--with-USE_TERMIO directive"?
It looks like things took a turn for the worst. After installing libncurses 5.2, I now get an "Undefined symbols: _winch" error for modules that compiled fine before. I know that winch is defined in both the Apple provided /usr/include/curses.h and the just installed libncurses 5.2 /usr/local/include/curses.h.
Note the Apple provided /usr/include/curses.h and the libncurses 5.2 /usr/local/include/curses.h are different sizes, Apples: 13.5kb and libncurses 5.2 is 60.7kb.
I tried "cc -L/usr/include ..." and "cc -L/usr/local/include..." and both attempts reveal the same error.
I am really frustrated, and I don't know what else to but *gasp* re-install my entire system and reinstall all the libraries and sources. Which I would hate to do because most of beta 9 is now built....
Heeeelllp,
Jeshua Lacock
Cartographer/Owner
http://SierraMaps.com
http://3dTopoMaps.com
Telephone: (760) 935-4481
subject 'unsubscribe grass5'
