[GRASS5] _gtty & _stty errors
On Wednesday, December 6, 2000, at 06:55 PM, Jeshua Lacock wrote:
On Wednesday, December 6, 2000, at 06:10 PM, Eric G . Miller wrote:
> On Wed, Dec 06, 2000 at 03:31:57PM -0800, Jeshua Lacock wrote:
> > > > Report the same error:
> > > > /usr/bin/ld: Undefined symbols:
> > > > _gtty
> > > > _stty
> > > Those should be defined in libncurses, I think. Do you have the
> > > ncurses5 library installed? It may be the linker is not finding the
> > > libraries correctly (maybe use the --with-libs=/path/to/libdir). The
> > > linker is often very limited in where it will look for thing by default,
> > > hence all the -L/usr/X11R6/lib and similar flags. See other post as
> > > well.
> > Hi gang,
> > Ok, I installed the libncurses 5.2 and it appears that they were already installed
> because modules that compiled before gave a error stating that
> "/usr/lib/libncurses.a is out of date; rerun ranlib(1)". After updating with ranlib
> the modules that worked before now work, however, I still get the errors with the above
> modules:
> > _gtty
> > _stty
> > Which leads me to believe that they must be defined somewhere else.... Where??
> > I would really like to figure this one out as it will fix 6 modules....
> Well, not sure where those get defined, but I find "gtty" and "stty" in
> libc.a. I couldn't find those symbols in libncurses.a, libcurses.a, or
> libtermcap.a -- sorry for the red herring. You can use "nm
> /path/to/staticlib.a | grep '<symbol>'" to hunt for where symbols are
> defined. See if libc.a has 'stty' (it probably does). Are you using
> the --with-USE_TERMIO directive? If not, maybe it's worth a try.
Hi Eric,
Where would use the "--with-USE_TERMIO directive"?
It looks like things took a turn for the worst. After installing libncurses 5.2, I now get
an "Undefined symbols: _winch" error for modules that compiled fine before. I know that
winch is defined in both the Apple provided /usr/include/curses.h and the just
installed libncurses 5.2 /usr/local/include/curses.h.
Note the Apple provided /usr/include/curses.h and the libncurses 5.2
/usr/local/include/curses.h are different sizes, Apples: 13.5kb and libncurses 5.2
is 60.7kb.
I tried "cc -L/usr/include ..." and "cc -L/usr/local/include..." and both attempts
reveal the same error.
I am really frustrated, and I don't know what else to but *gasp* re-install my entire
system and reinstall all the libraries and sources. Which I would hate to do because most
of beta 9 is now built....
Heeeelllp,
Jeshua Lacock
OK, I'm back after re-installing my system.
It appears that gtty and stty are defined in the header libc.h (which is on my system), however I cannot locate the archive libc.a anywhere on my system. I suspect that this may be the problem, can someone confirm this?
Does anyone know where to get libc.a? Would it work if someone emailed it to me (off list, of course)?
Danka,
Jeshua Lacock
Cartographer/Owner
http://SierraMaps.com
http://3dTopoMaps.com
Telephone: (760) 935-4481
subject 'unsubscribe grass5'
confirm this?
You need to get a copy of the static C library for Mac OS X. Possibly
available in developer's resources or some such. Apparently you only
have the shared libes ?? (libc.so or libc.o). It's likely much to big
to mail and it *must* be built for that system. Mine weighs in around
2.5 MB.
Eric G. Miller <egm2@jps.net>
