On Tue, Jun 20, 2000 at 10:50:16AM +1000, James Cameron wrote:
The checkout finished okay.
I'm surprised "make" doesn't actually do the compilation.
Why is that?
Hi James,
.. from the INSTALL file:
"The 'make' command at time only generates a few internal files."
Reason is that GRASS needs *full* autoconf - some more work.
The "make install" took 56 minutes on my machine. At the end it
suggested a few other things to be done. Shouldn't it do it all
for me?
In my opinion it is better like this as the modules not compiled
by the script are highly dependent on MESA, tcl/tk and other stuff.
If we would include it, many others (who don't have installed MESA etc.)
would complain: why does it not compile?
It said;
* Finally run 'gmakelinks5' to finish the installation process.
But there is no gmakelinks5 present; "find . -name gmakelinks5"
gives me nothing. But it is present in /usr/local/bin ... ah.
So /usr/local/bin is not in your path. Call it:
/usr/local/bin/gmakelinks5
On activating it I get a lot of "Creating link" output. But I
got that from the "make install" anyway.
O.k., there might be a bit of inconsistency. But gmakelinks5 does
not break anything. So it does not matter to run it twice.
You will have to run it always after manually compiling a new module
for GRASS.
We would be glad to find someone taking care for a full "autoconf"
and "make" working as expected. You are welcome to help!
Best wishes
subject 'unsubscribe grass5'
