[GRASS5] help regarding grass and garsslinks
hi
              i am working with grass5 and grasslinks3.1.i am getting the error in create_gif sub program.the code where i am getting error is
&system_errors_logged("$PBM_PATH/ppmquant 256 < $ENV{MAPLP} 2> /dev/null | $PBM_PATH/ppmtogif -interlace > $TMP/$value{GIF} 2>
           /dev/null");
error is sh: /apache/htdocs/grasslinks/tmp/pmap.grasslinks1 is not a file or directory. i observed that the grasslinks won't create any file called pmap.grasslinks1. i did't get any clue on this from the net.one more thing in installation guide also no clue about this one.can any body tell me the problem where i m doing mistake.please help me.waiting for reply
Thanks & Regards
  G Anand Mohan
Hi
at least tested to work on my server
grasslinks-reimplemented prog called 'webgrass'
You may wish to try that one on:
http://tigers.ru/webgrass_e/index.html
and take the source at
http://tigers.ru/webgrass_e.tar.gz
Hint: check write permissions for the apache user (
often it is 'nobody') for the tmp directory where
temporary files are stored.
Good luck
--- Anand Mohan <anand@mail.arkinsys.com> wrote:
hi
Iam working with grass and grasslinks. I am not
able to display the selected map in the browser.In
create_gif subroutine gif is creating under tmp file
with out any data in the file.can any body help me
in this regard what may be the problem.I observed
that paint.ppm file is not there under home
directory.is it create dynamically.please help me in
this regard.
Thanks & Regards
Anand Mohan G
grass5 mailing list
grass5@grass.itc.it
http://grass.itc.it/mailman/listinfo/grass5
__________________________________________________
Do You Yahoo!?
Send FREE video emails in Yahoo! Mail!
http://promo.yahoo.com/videomail/
