[GRASS5] Help
How get I a JNI for GRASS5 beta11?? o What I have to do to compile with
GRASS 5?
I tried to compile the GRASS JNI that comes with the GRASS 5 beta 11
source code in the folder src.garden/grass.java. I have java 1.2 sdk. The
.jar compiled good, but it show me to much warnings and when I ran
examples check1 and check2 show:
Exception in thread "main" java.lang.UnsatisfiedLinkError: no gis in
java.library.path
        at java.lang.ClassLoader.loadLibrary(Compiled Code)
        at java.lang.Runtime.loadLibrary0(Compiled Code)
        at java.lang.System.loadLibrary(Compiled Code)
        at GRASS.libgis.<clinit>(libgis.java:958)
        at check1.<init>(Compiled Code)
        at check1.main(Compiled Code)
make: *** [check1] Error 1
      xxxxx
        xx xxx
       xx xx x xxxxx
      xxxxx xx x xx xxxxxx
             xxx xxx xx
                   xx xx
                           xx
     sldla996@bochica.udea.edu.co
     zoftwar@yahoo.com
     david@lozano.as
     dlozano@dada.udea.edu.co
     lenin@cigoto.8k.com
     zoftwar@latinmail.com
subject 'unsubscribe grass5'
