[GRASS5] how to install software grass into the linux platform...?
hi!
I want to develop one project that related to this software grass..but i had a problem to solved in by myself..i want to know how can i run this software grass into linux platform....and then to the server sun solaris sparc... ?
Reply-To: grass5@geog.uni-hannover.de
Subject: [GRASS5] Compilation on HP-UX
Date: Mon, 16 Apr 2001 18:08:52 -0400
Finally I found time to try compile GRASS on HP-UX.
I download the last snapshut of GRASS and proceeded
to compile it. So, I run ./configure and got somme
checking with negative results. I want to know if they
may cause problems.
checking for flex... lex
??? the REQUIREMENT files say flex no lex is suported.
??? flex is available for HP-UX
Are they any problems with thoses ?
checking for bison... no
checking for byacc... no
checking for dnet_ntoa in -ldnet... no
checking for dnet_ntoa in -ldnet_stub... no
checking for seteuid... no
checking for initscr in -lncurses... no
checking for initscr in -lcurses... yes
checking for xdrmem_create in -lsun... no
checking for xdrmem_create in -lnsl... no
checking for xdrmem_create in -lrpclib... no
checking for atan in -lc... no
checking for atan in -lm... yes
checking for dlsym in -ldl... no
I have some missing libraries that are easy to correct.
Thanks.
Robert Lagacé, professeur
Pavillon Comtois
Université Laval
Ste-Foy, Québec, G1K 7P4
tel : (418)-656-2131#2276
Fax : (418)-656-3723
E-mail : lagace@grr.ulaval.ca
subject 'unsubscribe grass5'
_________________________________________________________________________
Get Your Private, Free E-mail from MSN Hotmail at http://www.hotmail.com.
---------------------------------------- If you want to unsubscribe from GRASS Development Team mailing list write to:
On Tue, Apr 17, 2001 at 12:53:59AM -0000, ja id wrote:
hi!
sparc... ?
GRASS is running both on Linux and Solaris. You either compile the source
code or install pre-compiled binaries.
See for downloads here:
http://www.geog.uni-hannover.de/grass/download.html
Hope this helps,
Markus Neteler
>From: Robert Lagacé <lagace@grr.ulaval.ca>
>may cause problems.
>Thanks.
>Pavillon Comtois
>Université Laval
>to:
Markus Neteler * University of Hannover
Institute of Physical Geography and Landscape Ecology
Schneiderberg 50 * D-30167 Hannover * Germany
Tel: ++49-(0)511-762-4494 Fax: -3984
ja id wrote:
hi!
sparc... ?
GRASS is already compiled for Linux and Solaris. So you are OK.
Download the binaries.
>may cause problems.
>Thanks.
>Pavillon Comtois
>Université Laval
>to:
Pavillon Comtois
Université Laval
