[GRASS5] How to write to a vector coverage?
To whomever may be of assistance,
I am working on a vector import method for Trimble .ssf files. I have most of the file format worked out. Now I need to find a way to put the information into grass. My target version is 5.3.
I took a look at the grass 5 programming manual, and did not find what I'm looking for.
How can I open an existing vector coverage and add features to it. The documentation indicates that we have a read only interface for existing data and a write only interface for new data. How can we add new data to an existing coverage? Can you provide an example of code that does this?
Alternatively, is there a high level file format that is easy to generate with which I could use an existing import utility to bring the data into grass?
I did not find structs for point, line, area, etc. How much information can be encoded with vector information? I understand that we can do diferent map layers, and can assign category numbers in those layers. So we could have a database like:
Layer Category
Roads
  1. US 95
  2. SW 48th st
Waterways
  1. Porcupine Creek
  2. Octopus River
Can we encode any of the following information with a vector:
Error / variance for points?
Elevation of points?
Other observations like regions with continous (non - categorical) measurements like density associated with each region.
Can the vector implementation handle features which are single points of data, or will I need to make site coverages for these?
Thank you in advance for your time and input,
Cedric Shock
