[GRASS5] html help
Hello,
I have netscape running, and when I do a Ctrl-middle button on a
tcltkgrass-module, I get the corresponding html man page. But I also get the
message that /usr/bin/X11/netscape is not running and that I need to start it
first. Why ?
Moritz
subject 'unsubscribe grass5'
On Thu, Feb 15, 2001 at 12:33:49PM +0100, mlennert@club.worldonline.be wrote:
Hello,
first. Why ?
Hi Moritz,
I have the same problem. If netscape isn't already started, you don't
receive the man-page. Reason is the command used in gui.tcl:
netscape -remote
This only works if netscape is already started. The gui.tcl needs
to be modified to get a test if netscape is present, if not, start it.
Tcl-Volunteers? :slight_smile:
Hello,
I am trying to build the latest GRASS on my Solaris machine. The version
is up to date from the CVS yesterday (feb. 14).
The problem I am having is the GIS lib is not getting built, which is of
course rather important. The GIS lib is failing with file flate.c at
line 120. The comments in the file indicate that this will fail if ZLIB
is not installed. The libz is installed in /usr/local/bin.
Any thoughts on what I am doing wrong? It sucessfully built on Linux
without problem.
Bob Covill
Tekmap Consulting
P.O. Box 2016
Fall River, N.S.
B2T 1K6
Canada
E-Mail: bcovill@tekmap.ns.ca
Phone: 902-860-1496
Fax: 902-860-1498
Hi Bob,
Solaris has got some issues currently. Se your zlibs manually with:
--with-zlib-<includes|libs>=[dir]
What version of Solaris are you running? Solaris 7 is where the
conflicts show up with configure.
Bruce
Bob Covill wrote:
Hello,
without problem.
Bob Covill
Tekmap Consulting
P.O. Box 2016
Fall River, N.S.
B2T 1K6
Canada
Phone: 902-860-1496
Fax: 902-860-1498
On Thu, Feb 15, 2001 at 11:32:06AM -0400, Bob Covill wrote:
Hello,
without problem.
Bob Covill
Bob,
did you try to specify the path?
configure --with-zlib-includes=DIR --with-zlib-libs=DIR
This should help.
> Hello,
> without problem.
> Bob Covill
Bob,
This should help.
Markus,
I have tried specifying the zlib and zinclude paths with configure with the same
result. Configure has no trouble with zlib. The error generated is " 'NULL'
undeclared (first use in function)". Where should it be seeing the definition of
NULL?
Bob Covill
Tekmap Consulting
P.O. Box 2016
Fall River, N.S.
B2T 1K6
Canada
Phone: 902-860-1496
Fax: 902-860-1498
> > Hello,
> > without problem.
> > Bob Covill
> Bob,
> This should help.
> Markus
Markus,
NULL?
Probably I know the problem! The configure should set:
HAVE_ZLIB_H
in src/include/config.h
Maybe this wasn't successful? The flate.c has a test:
#ifndef HAVE_ZLIB_H
static void
break_compile (void)
    /* if ZLIB is not installed, a compile error is generated here */
    NULL = 1;
So the compiler will break if HAVE_ZLIB_H is not set.
Check the src/include/config.h.
Regards
> > > Hello,
> > > without problem.
HAVE_ZLIB_H
#ifndef HAVE_ZLIB_H
static void
    NULL = 1;
Regards
Markus,
You were close. It appears that flate.c was using the wrong config.h header. It was
reading one from /usr/local/include, and therefore not getting any defines. If I
manaully add the define HAVE_ZLIB_H to flate.c or add the full path to config.h it
compiles cleanly.
The problem should be solvable by ensuring that the first "-I" flag looks in
grass/src/include instead of picking other config.h files.
Bob Covill
Tekmap Consulting
P.O. Box 2016
Fall River, NS
Canada
B2T 1K6
On Thu, Feb 15, 2001 at 01:44:01PM -0400, Bob Covill wrote:
Markus,
header. It was reading one from /usr/local/include, and therefore not
getting any defines. If I manaully add the define HAVE_ZLIB_H to
flate.c or add the full path to config.h it compiles cleanly.
What the heck puts a config.h in /usr/local/include ? I'd think that
would break a lot of software builds as config.h is the de facto
standard name for defining "configure" output.
looks in grass/src/include instead of picking other config.h files.
Yes, it should probably always be -I. -I$(SRC)/src/include <whatever>.
Eric G. Miller <egm2@jps.net>
> Markus,
This I have seen this idea in other projects, too.
Where to add -I.? In make.mid / CFLAGS=
> > Markus,
Markus & Eric,
I changed the order of EXTRA_CFLAGS and INCLUDE_DIR on the CFLAGS line of
make.mid in generic. This seems to have solved the problem of accidentally
picking up other config.h files (which apparaently should not be there in the
first place).
I have not compiled the whole thing yet so I do not know if it will have an
adverse affect down the road.
Bob Covill
Tekmap Consulting
P.O. Box 2016
Fall River, N.S.
B2T 1K6
Canada
Phone: 902-860-1496
Fax: 902-860-1498
