[GRASS5] html to man conversion
On Thu, Nov 30, 2000 at 03:30:32PM +0100, mlennert@club.worldonline.be wrote:
> > On Thu, Nov 30, 2000 at 03:05:43PM +0100, mlennert@club.worldonline.be wrote:
> > > Hello,
> > > During compilation of CVS-tree I get the following type of error message for
> > > every man page:
> > > Converting: m.tiger.region.html to /usr/local/grass5/man/man1/m.tiger.region_.1
> > > man: can't create index cache /usr/local/grass5/man/index.bt: Permission denied
> > > Reformatting m.tiger.region_(1), please wait...
> > > m.tiger.region_.1 => m.tiger.region.1
> > > Converting: m.u2ll.html to /usr/local/grass5/man/man1/m.u2ll_.1
> > > Reformatting m.u2ll_(1), please wait...
> > > m.u2ll_.1 => m.u2ll.1
> > > I left my compilation running, since I don't know if this is important, so
> > > I'll see what's going to happen, but I thought I'd already signal it.
> > Hi Moritz,
> > this should be fixed since a few days. Please
> > cvs update html/Gmakefile
> > cd html
> > gmake5
> > and report, if this error is still there. Michel has added
> > "chown man"
> > which should be helping.
> > Markus
> I just redownloaded the entire cvs tree and that is what I am compiling. But I
> can try to update again once the current compilation is done.
O.k., then it seems to be still a problem.
Michel, do you have an idea?
Well, I did the update of the Gmakefile after the compilation and now I didn't get any error messages anymore. I don't no, if for some reason I didn't get the latest version of the cvs tree (but I did erase the entire tree and reinstalled it, following the instructions) or wether something else later in the compilation process made the compilation the html directory possible... I can't check wether the manual pages work because Grass isn't running yet. In the grass5/man directory, only man1 has any content at all. The other ones (man2-5 and help) are empty and only man1 has 'man' as its owner.
Moritz
subject 'unsubscribe grass5'
On Thu, Nov 30, 2000 at 04:29:57PM +0100, mlennert@club.worldonline.be wrote:
> > > > Hello,
> > > > every man page:
> > > Hi Moritz,
> > > cd html
> > > gmake5
> > > "chown man"
> > > Markus
Strange.
Yes, only man1 will contain *all* files as no "classification" is done (due
to the fact that html files are the source). We *may* add a keyword to each
page to allow separations and storage into different man? directories. But
personally I don't think that this extra works makes much sense.
So, if g.manual doesn't work: cvs update it as well and run the gmake5.
Perhaps you have left the old g.manual *module* (now it is a script).
Check if g.manual still exists in $GISBASE/bin and $GISBASE/etc/bin/...).
Yes, this might be the reason for your problem.
The current module offer these parameters:
g.manual help
Usage:
g.manual [-1] [-a] [-d] [-m] [-s] [-q] [browser=name]
[entries=name[,name,...]]
   name name ...
Hope this helps
Strange.
Well, sorry for not being very reactive, but I'm a little overloaded,
and worse, the network here is in maintenance : I won't have any access
until next week !
The `chown' line works only if root runs make. The problem is
that the index is made by a program suid man, so if the user "man"
cannot write in the man directory, you get an error message each
time g.html2man runs ! On the other hand a "normal" user cannot
give the directory to man (or cannot write man pages after that)
A better idea is to say "chmod a+w $(MANDIR)", and to restore
the read-only flag after all pages are created (for security
reasons). Sorry, I have no time (and no network) until next week
to do that ! but it's straightforward :wink:
Michel WURTZ - DIG - Maison de la télédétection
               500, rue J.F. Breton
               34093 MONTPELLIER Cedex 5
Unset that suid bit instead. Is there some reason the man
command is suid?
If there's a way to generate the man pages inside of the source tree,
including the index, and then "install" them into the man/man1
destination, I think that would be better/safer. Don't know if index.bt
needs the full path or just relative would do? I looked around at my
system man dirs, and other than this new grass one, there doesn't seem
to be any kind of index for man pages (there is a cache in
/var/cache/man). So, is the index really necessary? I have close to no
clue about the variants of man programs...
Eric G. Miller <egm2@jps.net>
> Strange.
until next week !
Hi Michel,
perhaps for you list:
if I run this on CRAY, I get:
Make: "chown man /home/t3e/fsn/nhdc/nhdcmark/grass5bin/man/man1 2> /dev/null
;true": Error code 4
t3e:grass/html:585$ man chown
IMPLEMENTATION
     CRAY T3E systems
STANDARDS
     POSIX, XPG4
     AT&T extensions (-h option)
The reason is:
cmd-1362 chown: Unknown user id 'man'.
At least on CRAY it is:
ls -la /usr/man
total 1248
drwxr-xr-x 10 bin bin 4096 Jun 1 1999 .
I am installing as user, not as root here.
We need a more portable implementation...
Regards
Hi again,
unfortunately another bug found on SUN in
html/Gmakefile
Copying html pages
/bin/sh: test: unknown operator -ot
I don't know the meaning of -ot, but it's not portable
(Huidae, Michel?).
Hi again,
html/Gmakefile
Copying html pages
(Huidae, Michel?).
Uh ? excerpt from SunOS 5.7 man page of test
     file1 -ot file2
               True, if file1 exists and is older than file2.
BUT... [ or test are in /usr/ucb or /usr/bin for sun =>
$ if /usr/bin/test Lespinard.zip -ot Duclaux.zip ; then echo ok ; fi
ok
$ if /usr/ucb/test Lespinard.zip -ot Duclaux.zip ; then echo ok ; fi
Conclusion :
if test file1 -ot file2 ; then echo ok ; fi # doesn't work
if /bin/test file1 -ot file2 ; then echo ok ; fi # works !
Silly mixing of old SunOS and new Solaris versions... !
Hi Michel,
some times ago reported, again investigated...
> Hi again,
> html/Gmakefile
> Copying html pages
> (Huidae, Michel?).
     file1 -ot file2
ok
Conclusion :
I have checked that. And I have renamed
/usr/ucb/test
to
/usr/ucb/test_old
.. but above problem is still there.
The "-ot" test occurs from
html/Gmakefile:
if [ ! -f $$f -o $$f -ot $$h ]
So "test" is not called directly. How can we fix this?
My path settings are on Solaris:
PATH=.:/usr/sbin:/usr/bin:/usr/openwin/bin:/opt/SUNWspro/bin:/opt/SUNWspro/SC3.0.1/bin:/usr/ucb:/export/home/gnu/bin:/data/sara-neu:/export/home/OPT/comm/bin:/usr/local/bin:/usr/ccs/bin:/usr/local/netpbm
Regards
Hi Markus
> > Hi again,
> > html/Gmakefile
> > Copying html pages
> > (Huidae, Michel?).
> file1 -ot file2
> ok
> Conclusion :
/usr/ucb/test
to
/usr/ucb/test_old
html/Gmakefile:
It has to be changed since the -ot option is not supported on SGI
machines. Perhaps we could use the getModTime function I added to
src/general/init but then it would need to be compiled before the html
conversion.
Sincerely,
Jazzman (a.k.a. Justin Hickey) e-mail: jhickey@hpcc.nectec.or.th
High Performance Computing Center
National Electronics and Computer Technology Center (NECTEC)
Bangkok, Thailand
People who think they know everything are very irritating to those
of us who do. ---Anonymous
Jazz and Trek Rule!!!
On Mon, Jan 15, 2001 at 07:24:36PM +0700, Justin Hickey wrote:
Hi Markus
> > > Hi again,
> > > html/Gmakefile
> > > Copying html pages
> > > (Huidae, Michel?).
> > file1 -ot file2
> > ok
> > Conclusion :
> /usr/ucb/test
> to
> /usr/ucb/test_old
> html/Gmakefile:
conversion.
Hi Justin,
generally I don't see a problem to compile such tools. DO you
see a change to implement that?
Yours
Hello GRASS list:
I am a new user hoping to learn the hydro simulation modeling capabilities of
GRASS as well as its spatial stat components. I am attempting to install GRASS
5.0 beta10 to a RedHat7.0 linux box. I have gunzipped and tared the files and am
ready to install, except I don't know where to run the ./configure and make
install commands. I cannot find the grass5.0beta directory as documented. Where
would this directory be? I assume in the same one as the other stuff. Anyways I
would appreciate your help.
Justin A Saarinen
MS Candidate
University of Florida Geography
Gainesville, Florida USA
> Hi Markus
> > > > Hi again,
> > > > html/Gmakefile
> > > > Copying html pages
> > > > (Huidae, Michel?).
> > > file1 -ot file2
> > > ok
> > > Conclusion :
> > /usr/ucb/test
> > to
> > /usr/ucb/test_old
> > html/Gmakefile:
> conversion.
Hi Justin,
Yours
Hi Markus
> html conversion.
Hi Justin,
Are there other "tools" like this (ie separate programs or scripts that
do not need to link to Grass)? If so we could group them together in a
directory and compile them first. If not, we could move the getModTime.c
file to the html directory and compile it there.
Sincerely,
Bangkok, Thailand
On Wed, Jan 17, 2001 at 01:33:10PM +0700, Justin Hickey wrote:
Hi Markus
> > html conversion.
> Hi Justin,
Hi Justin,
let's add
src/libes/tools
as later other tools might be added. It's better than mixing .c code
and .html.
Yours
Hi Markus
let's add
src/libes/tools
and .html.
Done. Now we just need to rewrite that -ot code.
Sincerely,
Bangkok, Thailand
