Hello,
has anyone out there i.rectified2 a plane bitmap (x,y) onto a DEM (globe)
using the latest i.rectify2 module? (CVS)
Here is what i did:
1. r.in.ppm of the image into imagery dataset
2. logged out / logged into world dataset
3. g.region of target area
4. log out of world dataset -> imagery
5. i.group & i.target & i.points
6. i.rectify2 (3rd order poly (but didn't matter on later tries))
7. got a mail: couldn't write row ...
I checked diskspace but there was plenty left (~several GB)
(imager cell size is 20mb)
resolution of world dataset ~0:0:30
resolution of imagery dataset ~1point/km
(I took the commands from gr-tut98.ps & and imagery.ps)
After digging into the mailinglist i found that several people had
already a try on this, so i decided to ask here.
regards,
Christoph
PS: Anyone having bathymetry/seafloor data (1-2 minute/1meter vertical) in
compressed (gzip/bzip2) form as i'm trying to produce a r.tides module
subject 'unsubscribe grass5'
HI Christoph,
you need at least GRASS 5 beta7. Otherwise it won't work.
Which GRASS 5 do you have?
On Thu, Jun 22, 2000 at 06:33:19PM +0200, C.Hoegl@gmx.net wrote:
Hello,
Here is what i did:
regards,
Christoph
Dipl.-Geogr. Markus Neteler * University of Hannover
Institute of Physical Geography and Landscape Ecology
Schneiderberg 50 * D-30167 Hannover * Germany
Tel: ++49-(0)511-762-4494 Fax: -3984
On Mon, 26 Jun 2000, Markus Neteler wrote:
The version used is current from cvs (2000-06-23)
patching write.c like this
--- write.c Thu Jun 22 18:13:04 2000
+++ write.c.new Mon Jun 26 14:50:20 2000
@@ -66,7 +66,6 @@
/* BUGFIX: printf substituted with sprintf */
sprintf(buf, "error writing row %d\n", row);
- G_fatal_error(buf);
if(G_put_raster_row(fd,rast, map_type) < 0)
one gets all files (and a success mail)
displaying the result (d.rast in the world dataset) the raster looks like
torn into stripes. (large white fields with data intermixed on a line
base)
(the image is to large to post here)
(color space seems to cycle from red to green and blue within the image
which is not true for the source ppm)
HI Christoph,
> Hello,
> Here is what i did:
r.in.tiff
seems to be broken if tifflib has -ljpeg and -lz compiled in.
I try to fix this using a smarter configuration test
regards,
Christoph
