I've had this issue for some time and am now just looking into it. I
don't know if this is a 64-bit issue or not. Can anyone replicate this
under 32-bit architectures?
I'm no expert with gdb, either and use it so rarely I cannot remember
how to probe structures:
GRASS 6.1.cvs (spearfish60):/usr/src/grass6 > gdb --args i.smap gr=b
sub=b sig=b out=b
[snip]
(gdb) run
Starting program: /opt/gis/grass-6.1.cvs/bin/i.smap gr=b sub=b sig=b
out=b
Processing rows 1-128 (of 700), cols=1-128 (of 950)
Processing rows 1-128 (of 700), cols=129-256 (of 950)
Processing rows 1-128 (of 700), cols=257-384 (of 950)
Processing rows 1-128 (of 700), cols=385-512 (of 950)
Processing rows 1-128 (of 700), cols=513-640 (of 950)
Processing rows 1-128 (of 700), cols=641-768 (of 950)
Processing rows 1-128 (of 700), cols=769-896 (of 950)
Processing rows 1-128 (of 700), cols=897-950 (of 950)
Processing rows 129-256 (of 700), cols=1-128 (of 950)
Processing rows 129-256 (of 700), cols=129-256 (of 950)
Processing rows 129-256 (of 700), cols=257-384 (of 950)
Processing rows 129-256 (of 700), cols=385-512 (of 950)
Processing rows 129-256 (of 700), cols=513-640 (of 950)
Processing rows 129-256 (of 700), cols=641-768 (of 950)
Processing rows 129-256 (of 700), cols=769-896 (of 950)
Processing rows 129-256 (of 700), cols=897-950 (of 950)
Processing rows 257-384 (of 700), cols=1-128 (of 950)
Processing rows 257-384 (of 700), cols=129-256 (of 950)
Processing rows 257-384 (of 700), cols=257-384 (of 950)
Processing rows 257-384 (of 700), cols=385-512 (of 950)
Processing rows 257-384 (of 700), cols=513-640 (of 950)
Processing rows 257-384 (of 700), cols=641-768 (of 950)
Processing rows 257-384 (of 700), cols=769-896 (of 950)
Processing rows 257-384 (of 700), cols=897-950 (of 950)
Processing rows 385-512 (of 700), cols=1-128 (of 950)
Processing rows 385-512 (of 700), cols=129-256 (of 950)
Processing rows 385-512 (of 700), cols=257-384 (of 950)
Processing rows 385-512 (of 700), cols=385-512 (of 950)
Processing rows 385-512 (of 700), cols=513-640 (of 950)
Processing rows 385-512 (of 700), cols=641-768 (of 950)
Processing rows 385-512 (of 700), cols=769-896 (of 950)
Processing rows 385-512 (of 700), cols=897-950 (of 950)
Processing rows 513-640 (of 700), cols=1-128 (of 950)
Processing rows 513-640 (of 700), cols=129-256 (of 950)
Processing rows 513-640 (of 700), cols=257-384 (of 950)
Processing rows 513-640 (of 700), cols=385-512 (of 950)
Processing rows 513-640 (of 700), cols=513-640 (of 950)
Processing rows 513-640 (of 700), cols=641-768 (of 950)
Processing rows 513-640 (of 700), cols=769-896 (of 950)
Processing rows 513-640 (of 700), cols=897-950 (of 950)
Processing rows 641-700 (of 700), cols=1-128 (of 950)
Processing rows 641-700 (of 700), cols=129-256 (of 950)
Processing rows 641-700 (of 700), cols=257-384 (of 950)
Processing rows 641-700 (of 700), cols=385-512 (of 950)
Processing rows 641-700 (of 700), cols=513-640 (of 950)
Processing rows 641-700 (of 700), cols=641-768 (of 950)
Processing rows 641-700 (of 700), cols=769-896 (of 950)
Processing rows 641-700 (of 700), cols=897-950 (of 950)
Writing [b] ...
0%
Program received signal SIGSEGV, Segmentation fault.
0x0000000000402887 in write_img (img=Variable "img" is not available.
) at write_img.c:28
28 files->cellbuf[col] = (CELL)S->ClassSig[class].classnum;
(gdb) bt
#0 0x0000000000402887 in write_img (img=Variable "img" is not
available.
) at write_img.c:28
#1 0x0000000000402eb3 in segment ()
#2 0x000000000040224a in main (argc=5, argv=Variable "argv" is not
available.
) at main.c:27
(gdb)
Brad Douglas <rez@touchofmadness.com>
