[GRASS5] i.vpoints deadlock
Dear developers,
while fiddeling arround with i.vpoints, I found a dead-lock situation.
You can reproduce it with the spearfish-dataset, where you need to
create a new group with some datasets included.
start i.vpoints, select vector and rasterdata, set more than 4 points
and select analyse.
You can change the transformation-order, but when hitting 1st order,
i.vpoints locks up...
to return to the GRASS-Promt you need to kill i.vpoints and the
corresponding monitor.
Perhaps someone more skilled than me can take a look?
Thanks in advance.
  Stephan Holl
Stephan Holl
Check headers for GnuPG Key!
http://www.gdf-hannover.de
