[GRASS5] "Illegal latitude for South" again
I think that we should find a solution for problems
like this one:
g.region n=90N s=90N w=180W e=180E res=0:20
r.in.onearth -b out=bluemarble_global_mosaic
************* DATA CHECK OK ***************
************** IMPORT DATA ****************
Driver: GTiff/GeoTIFF
Size is 1080, 540
Coordinate System is:
GEOGCS["WGS 84",
    DATUM["WGS_1984",
        SPHEROID["WGS 84",6378137,298.2572235629972,
            AUTHORITY["EPSG","7030"]],
        AUTHORITY["EPSG","6326"]],
    PRIMEM["Greenwich",0],
    UNIT["degree",0.0174532925199433],
    AUTHORITY["EPSG","4326"]]
Origin = (-180.000000,90.000000)
Pixel Size = (0.33333334,-0.33333334)
Metadata:
  AREA_OR_POINT=Area
  TIFFTAG_SOFTWARE=SGI's Image Format Library/1.2
Corner Coordinates:
Upper Left (-180.0000000, 90.0000000) (180d 0'0.00"W, 90d 0'0.00"N)
Lower Left (-180.0000000, -90.0000054) (180d 0'0.00"W, 90d 0'0.02"S)
Upper Right ( 180.0000107, 90.0000000) (180d 0'0.04"E, 90d 0'0.00"N)
Lower Right ( 180.0000107, -90.0000054) (180d 0'0.04"E, 90d 0'0.02"S)
Center ( 0.0000054, -0.0000027) ( 0d 0'0.02"E, 0d 0'0.01"S)
Band 1 Block=1080x2 Type=Byte, ColorInterp=Red
Band 2 Block=1080x2 Type=Byte, ColorInterp=Green
Band 3 Block=1080x2 Type=Byte, ColorInterp=Blue
A datum name wgs84 (WGS_1984) was specified without transformation parameters.
Note that the GRASS default for wgs84 is towgs84=0.000,0.000,0.000.
Projection of input dataset and current location appear to match.
Proceeding with import...
WARNUNG:G_set_window(): Illegal latitude for South
(It's even an error btw., import fails).
Apparently the NASA WMS delivers maps slightly larger.
Instead of leaving the user alone with that problem which
also appears with other world data sets I suggest to
have a GRASS environment variable to optionally cut
the map or whatever is appropriate in the underlying code.
Any ideas?
On Monday 16 January 2006 21:08, Markus Neteler wrote:
like this one:
Size is 1080, 540
GEOGCS["WGS 84",
    DATUM["WGS_1984",
Metadata:
  AREA_OR_POINT=Area
Corner Coordinates:
Any ideas?
The problem disappears if i set the resolution to 0:15 or 0:30,
but thats only a workaround.
Maybe this little code helps a bit?:
-->line 262 in r.in.onearth
  #We have LatLong projection, no warp is needed!
  USEGDALWARP=1
  #There is a bug in nasa WMS service, it provides images which are lager then
  #the world :(, we have to crop the images
  if [ "$n" == "90" -a "$s" == "-90" -a "$w" == "-180" -a "$e" == "180" ] ; then
  # check if we have bc
  if [ ! -x "`which bc`" ] ; then
    echo "bc required, please install first" 2>&1
    exit 1
  fi
   n=`echo "$n - 0.001" | bc`
   s=`echo "$s + 0.001" | bc`
   e=`echo "$e - 0.001" | bc`
   w=`echo "$w + 0.001" | bc`
  fi
Its not nice, but it works for me. I tried dgalwarp -et but i didnt work. :frowning:
New version of r.in.onearth available:
http://www-pool.math.tu-berlin.de/~soeren/grass/modules/r.in.onearth.tar.gz
Soeren
grass5 mailing list
grass5@grass.itc.it
http://grass.itc.it/mailman/listinfo/grass5
