[GRASS5] importing ASTER images using hdf2bin and r.in.bin?
I've been trying to import ASTER images using the hdf2bin tool and then
importing the resulting files using r.in.bin with limited success. The
hdf2bin program gives be the a list of the following information:
Swath "TIR_Swath" has following mapping information:
  Regular dimension mapping between geo and data fields:
     GeoTrack/ImageLine,GeoXtrack/ImagePixel
  Mapping increment = 70 83
  Mapping offset = 0 0
Geolocation field(s): Latitude,Longitude
Data field(s): ImageData10,ImageData11,ImageData12,ImageData13,ImageData14
Swath "TIR_Swath" contains following field(s):
float64 SWATH_TIR_Swath_Latitude.dat (GeoTrack=11,GeoXtrack=11)
  Data type: 64-bit floating point
  Number of Dimensions: 2
    Dim 1: "GeoTrack" = 11
    Dim 2: "GeoXtrack" = 11
float64 SWATH_TIR_Swath_Longitude.dat (GeoTrack=11,GeoXtrack=11)
uint16 SWATH_TIR_Swath_ImageData10.dat (ImageLine=700,ImagePixel=830)
  Data type: unsigned 16-bit integer
    Dim 1: "ImageLine" = 700
    Dim 2: "ImagePixel" = 830
uint16 SWATH_TIR_Swath_ImageData11.dat (ImageLine=700,ImagePixel=830)
uint16 SWATH_TIR_Swath_ImageData12.dat (ImageLine=700,ImagePixel=830)
The first three files import correctly, that is to say I can import them at
all and the rest give me the following:
GRASS:~ > r.in.bin input=SWATH_TIR_Swath_ImageData11.dat r=700 c=830
output=tir11
Using N=700.000000 S=0.000000 E=830.000000 W=0.000000
Bytes do not match File size
File Size 1162321 ... Total Bytes 581000
Try bytes=2 or adjusting input parameters
GRASS:~ >
Even when I include the bytes=2 argument, I get an error. Is there something
I'm doing wrong or is the file and/or GRASS broken? Or is there a better way
to import HDF-EOS files into grass? I'm running
GRASS 5.0.3 on cygwin and r.in.hdf isn't found and I haven't had the nerve
to try to compile GRASS with gdal support although I have been able to get
GRASS to build on my machine.
Jeff.
Jeff D. Hamann
Forest Informatics, Inc.
PO Box 1421
Corvallis, Oregon USA 97339-1421
(office) 541-754-1428
(cell) 541-740-5988
jeff.hamann@forestinformatics.com
www.forestinformatics.com
