[GRASS5] importing .e00 files
Does anyone have any ideas as to what might be wrong with the following command:
GRASS 6.1.cvs (arrowhead_utm):~ > v.in.e00 -v file=/Volumes/disk2/data2/reich_lab/data/fia/glo10k.e00 type=area vect=glo10k
An error may appear next which will be ignored...
E00 Compressed ASCII found. Will uncompress first...
/usr/local/grass-6.1.cvs/scripts/v.in.e00: line 175: e00conv: command not found
...converted to Arc Coverage in current directory
Importing areas...
ERROR: Cannot open data source: glo10k
An error occurred. Stop.
This files appears to open fine with ArcView, so I don't think the file is bad. However, I am confused by the "can't open data source" message.
Kirk
following command:
not found
Importing areas...
message.
This is the relevant error:
not found
You need e00conv (and avcimport) installed as e00 is not supported by
GDAL (yet). Get them from http://avce00.maptools.org/
There should have been a test to make sure you have them installed but
it seems to have failed. This is on Cygwin, right?
I've just updated the test:
was:
E00CONV=`which e00conv`
if [ "$E00CONV" = "" ] ; then
is now:
if [ ! -x "`which e00conv`" ] ; then
I think the string compare fails on Cygwin and generally you need to do
instead:
if [ -z "$E00CONV" ] ; then
The "! -x" I did above is just a simplification of the two lines.
(this is not an executable file of that name/path)
Could you test the CVS version of v.in.e00 and see if you get the error
now? (or just some command line tests?) If so we can get that fix in for
6.0.2 so others don't suffer the same problem.
We don't currently but probably should check the exit code of those
commands (with "$?") to make sure it all went ok.
The following scripts also do the [ "$x" = "" ] test, if I am right about
it not working on cygwin then they all need updating to [ -z "$x" ].
$ grep -rI '""' scripts/* | cut -f1 -d/ | sort | uniq
d.correlate
d.monsize
d.out.file
d.rast.leg
d.resize
d.slide.show
d.split
d.vect.thematic
db.test
g.mlist
g.mremove
i.fusion.brovey
i.image.mosaic
i.in.spotvgt
i.oif
i.spectral
i.tasscap
r.fillnulls
r.in.aster
r.in.srtm
r.mapcalculator
r.plane
r.reclass.area
r.regression.line
r.shaded.relief
r.univar.sh
r3.mapcalculator
v.build.all
v.convert.all
v.db.addcol
v.db.addtable
v.db.droptable
v.db.reconnect.all
v.db.update
v.in.garmin
v.in.gns
v.in.mapgen
v.in.sites.all
v.rast.stats
v.univar.sh
Hamish
following command:
not found
Importing areas...
message.
not found
was:
is now:
instead:
That fixed the error message Hamish. I did a cvs up this morning and re-ran the import (before installing avce00).
GRASS 6.1.cvs (arrowhead_utm):~ > v.in.e00 -v file=~/Desktop/glo10k.e00 type=area vect=glo10k
v.in.e00: 'avcimport' program not found, install it first
I built both avce00 and e00compr last night. The binaries are :
e00conv
avcdelete
avcexport
avcimport
avctest
ex_avcwrite
Do all of these go in my PATH (i.e /usr/local/bin)?
d.correlate
d.monsize
d.out.file
d.rast.leg
d.resize
d.slide.show
d.split
d.vect.thematic
db.test
g.mlist
g.mremove
i.fusion.brovey
i.image.mosaic
i.in.spotvgt
i.oif
i.spectral
i.tasscap
r.fillnulls
r.in.aster
r.in.srtm
r.mapcalculator
r.plane
r.reclass.area
r.regression.line
r.shaded.relief
r.univar.sh
r3.mapcalculator
v.build.all
v.convert.all
v.db.addcol
v.db.addtable
v.db.droptable
v.db.reconnect.all
v.db.update
v.in.garmin
v.in.gns
v.in.mapgen
v.in.sites.all
v.rast.stats
v.univar.sh
Hamish
Hey Shaun,
I'm still having some trouble with those .e00 files. I built avce00 and e00compr, and installed:
e00conv
avcdelete
avcexport
avcimport
avctest
in /usr/local/bin
I am no longer getting the error e00conv not found, but I still get the error "can't open data source:"
Importing areas...
Am I still missing something?
On Nov 2, 2005, at 12:29 PM, Shaun Walbridge wrote:
Hi Kirk,
You can just build avce00. It should be pretty straightforward to set up. Then either install the binaries to somewhere on your $PATH, or edit v.in.e00 to point to the locations. The GRASS dev folks should probably include it as a configure option, but I guess they see it as being external to the core GRASS stuff.
- Shaun
Kirk R. Wythers wrote:
Thanks Shaun. Does grass need to be re-compiled, or can I just build avce00?
On Nov 2, 2005, at 12:05 PM, Shaun Walbridge wrote:
Kirk,
The v.in.e00 script is dependent on your system having avce00 already installed. You can download this library at: http:// avce00.maptools.org/.
-Shaun
GRASS 6.1.cvs (arrowhead_utm):~ > v.in.e00 -v file=/Volumes/disk2/ data2/reich_lab/data/fia/glo10k.e00 type=area vect=glo10k
Importing areas...
Kirk
grass5 mailing list
grass5@grass.itc.it
http://grass.itc.it/mailman/listinfo/grass5
Hi Kirk,
please edit the first line of the v.in.e00 script
(run 'which v.in.e00' to find it, if that works on Mac)
and add
-x
to the first line. Then run again and it will print every step.
Please post the relevant part of the output.
On Thu, Nov 03, 2005 at 09:24:53AM -0600, Kirk R. Wythers wrote:
Hey Shaun,
e00conv
avcdelete
avcexport
avcimport
avctest
in /usr/local/bin
Importing areas...
>Hi Kirk,
>- Shaun
>>build avce00?
>>>Kirk,
>>>-Shaun
>>>>following command:
>>>>command not found
>>>>Importing areas...
>>>>Thanks,
>>>>Kirk
>>>>_______________________________________________
>>>>grass5 mailing list
>>>>grass5@grass.itc.it
grass5 mailing list
grass5@grass.itc.it
Markus Neteler <neteler itc it> http://mpa.itc.it
ITC-irst - Centro per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18 - 38050 Povo (Trento), Italy
On Nov 3, 2005, at 4:27 PM, Markus Neteler wrote:
Hi Kirk,
and add
-x
Markus,
I think this is the relevant output...
+ echo 'E00 Compressed ASCII found. Will uncompress first...'
+ rm -rf glo10k info
+ e00conv /Network/Servers/truffula.fr.umn.edu/Volumes/disk1/home1/kwythers/Desktop/glo10k.e00 13707.e00
+ echo '...converted to Arc Coverage in current directory'
+ avcimport 13707.e00 glo10k
++ echo glo10k
++ sed s+-+_+g
+ NAME=glo10k
+ '[' area = point ']'
+ '[' area = line ']'
+ '[' area = area ']'
+ echo 'Importing areas...'
Importing areas...
+ v.in.ogr -c -o dsn=glo10k layer=LAB,ARC type=centroid,boundary output=glo10k
+ '[' 1 -eq 1 ']'
+ echo 'An error occurred. Stop.'
+ rm -rf 13707.e00 glo10k info
+ exit 1
It's still that same "Cannot open data source: glo10k
Hey Shaun,
e00conv
avcdelete
avcexport
avcimport
avctest
in /usr/local/bin
Importing areas...
Hi Kirk,
- Shaun
build avce00?
Kirk,
-Shaun
following command:
command not found
Importing areas...
Kirk
grass5 mailing list
grass5@grass.itc.it
grass5 mailing list
grass5@grass.itc.it
Here is one more bit of info. If I use all three arguments point,line,area
the vector appears to import:
GRASS 6.1.cvs (arrowhead_utm):~ > v.in.e00 -v file=~/Desktop/glo10k.e00 type=point,line,area vect=glo10k
Imported point,line,area vector map <glo10k>.
Done.
However, g.list vect, does not show the new vector:
GRASS 6.1.cvs (arrowhead_utm):~ > g.list vect
no vector files available in current mapset
Hi Kirk,
and add
-x
Hey Shaun,
e00conv
avcdelete
avcexport
avcimport
avctest
in /usr/local/bin
Importing areas...
Hi Kirk,
- Shaun
build avce00?
Kirk,
-Shaun
following command:
command not found
Importing areas...
Kirk
grass5 mailing list
grass5@grass.itc.it
grass5 mailing list
grass5@grass.itc.it
Importing areas...
output=glo10k
+ '[' 1 -eq 1 ']'
what if you comment out the "rm" line? (244) (add a # at the start of it)
Then you can try v.in.ogr by hand, use ogrinfo, see what the file sizes
are, etc. (files are in a temp dir)
Hamish
point,line,area
Done.
right, that's a bug. (just not the bug you wanted)
#% options: point,line,area
#% description: Input type point, line or area
Note the "or".
the string matching tests which the parser uses apparently will consider
the whole options line as well as the components. I wonder what happens
if you add
#% multiple: no
Anyway it tests the string for each of point,line,area but as it is
never one individual value none of the three subroutines which handle
each case are actually run, and it exits bypassing them all thinking
everything was ok.
check for this added to the script in CVS.
Hamish
On Nov 3, 2005, at 7:55 PM, Hamish wrote:
Importing areas...
output=glo10k
+ '[' 1 -eq 1 ']'
On my system the last line in the file is 240. Are you referring to the line:
## area
         rm -rf $E00TMP.e00 $E00SHORTNAME info 2>&1 > /dev/null
or one of these:
#### clean up the mess
rm -f "$TMPDIR"/$E00NAME.e* "$TMPDIR"/$E00NAME.E*
rm -rf $E00TMP.e00 $E00SHORTNAME info $E00NAME.cat.$E00TMP.e00 2>&1 > /dev/null
cd ..
Can you give a little more detail here Hamish. Thanks.
Hamish
Importing areas...
output=glo10k
+ '[' 1 -eq 1 ']'
Hamish
I found the files in question. The newly created .e00 files appears to be names 750.e00. The structure looks like this:
in 750.0/
750.e00 glo10k/ info/
in glo10k/
dblbnd.adf lab.adf pat.adf
dbltic.adf par.adf prj.adf
in info/
arc.dir arc0000.nit arc0001.nit arc0002.nit arc0003.nit
arc0000.dat arc0001.dat arc0002.dat arc0003.dat
The file 750.e00 is 13 M (not that big). Which of these files I try v.in.ogr on?
Kirk
On Nov 3, 2005, at 3:18 PM, Shaun Walbridge wrote:
Hey Kirk,
Sorry I didn't respond earlier; your message was picked up by my GRASS mailing list filter and I hadn't gone through the messages. Are you still having problems importing your .e00 files? If so, there is an alternative approach: you can use the `avcimport' tool (came with the library you recently built) to convert the e00 compressed coverage into a simple binary coverage (It just unpacks the coverage into its native, non-compressed form). Afterward, you can use v.in.ogr to convert the Arc Coverage to a grass vector. The documentation is in v.in.ogr.html, and the example they use is:
*v.in.ogr dsn=*/coverage/ *layer=*/LAB,ARC/ *type=*/centroid,boundary/ *output=*/mymap
In addtion to working with v.in.e00, I have also tried Shaun's suggestion of using avcimport manually (creates 6 .adf files), then using v.in.ogr to import. I'm getting the same error "Cannot open data source".
GRASS 6.1.cvs (arrowhead_utm):~ > v.in.ogr dsn=~/Desktop/tmp/glo10ktest/ out=glo10ktest
        /Network/Servers/truffula.fr.umn.edu/Volumes/disk1/home1/kwythers/Desktop/tmp/glo10ktest/
This is probably caused by the same issue that was giving the v.in.e00 script fits. Any other thoughts?
Kirk
There is more information on the various layer types here:
http://www.gdal.org/ogr/drv_avc.html/
Hope this helps,
Shaun
Kirk R. Wythers wrote:/
Hey Shaun,
e00conv
avcdelete
avcexport
avcimport
avctest
in /usr/local/bin
GRASS 6.1.cvs (arrowhead_utm):~ > v.in.e00 -v file=~/Desktop/ glo10k.e00 type=area vect=glo10k
Importing areas...
Hi Kirk,
- Shaun
Kirk,
-Shaun
GRASS 6.1.cvs (arrowhead_utm):~ > v.in.e00 -v file=/Volumes/ disk2/ data2/reich_lab/data/fia/glo10k.e00 type=area vect=glo10k
Importing areas...
Kirk
grass5 mailing list
grass5@grass.itc.it
>>Importing areas...
WARNING (unrelated):
The -c flag must be taken out (already done in CVS) to get the
topology reconstructed. Otherwise no dissolve etc will work on the
imported map later on.
>> Importing areas...
>> output=glo10k
>> + '[' 1 -eq 1 ']'
> of it)
## area
or one of these:
> /dev/null
Comment them all out. The last one is mostly redundant by the way.
Try be hand with the files that are left behind.
Maybe better to add an 'echo' to the start of each line instead of a '#'
so you get to see what the file names are. "Quote" the text so the
redirection to /dev/null doesn't happen.
Hamish
Thanks to everyone for their suggestions on getting .e00 files imported. Here is the solution. I wanted to get it into the dev archives for others.
It turns out to be a Mac issue (big vs. little edian). avcimport's default build is to use the switch DCPL_LSB byte ordering. On a Mac (at least a G5 Mac) the byte order switch needs to be MSB (just like a Sun). Here is the bit of code in the GNUMakefile.
# Byte ordering ... default is Intel ordering (CPL_LSB),
# Select CPL_MSB for SUNs or other platforms with MSB first ordering.
BYTE_ORDER_FL = -DCPL_MSB
#BYTE_ORDER_FL = -DCPL_LSB
WIth that change (and re-building avcimport of course), the v.in.e00 script runs just fine.
Kirk
On Nov 6, 2005, at 3:01 PM, Markus Neteler wrote:
Kirk,
can you put the magic E00 somewhere and the output of
g.proj -wef > e00_prj.prj
Hey Kirk,
data source".
Kirk
Hope this helps,
Shaun
Hey Shaun,
e00conv
avcdelete
avcexport
avcimport
avctest
in /usr/local/bin
Importing areas...
Hi Kirk,
GRASS stuff.
- Shaun
build avce00?
Kirk,
-Shaun
Importing areas...
Kirk
grass5 mailing list
grass5@grass.itc.it
grass5 mailing list
grass5@grass.itc.it
I saw that right away, just didn't think to mention it. And I got distracted from building the avce00 stuff.
But, when I got to the e00compr program, I noticed that the byte order isn't specified in the makefile. Since e00compr and avce00 both use the CPL stuff, I suggest you add -DCPL_MSB to the e00compr CFLAGS also.
Kirk
Kirk,
Hey Kirk,
data source".
Kirk
Hope this helps,
Shaun
Hey Shaun,
e00conv
avcdelete
avcexport
avcimport
avctest
in /usr/local/bin
Importing areas...
Hi Kirk,
GRASS stuff.
- Shaun
build avce00?
Kirk,
-Shaun
Importing areas...
Kirk
grass5 mailing list
grass5@grass.itc.it
grass5 mailing list
grass5@grass.itc.it
grass5 mailing list
grass5@grass.itc.it
William Kyngesburye <kyngchaos@kyngchaos.com>
http://www.kyngchaos.com/
"I ache, therefore I am. Or in my case - I am, therefore I ache."
- Marvin
Kirk
Kirk,
Hey Kirk,
data source".
Kirk
Hope this helps,
Shaun
Hey Shaun,
e00conv
avcdelete
avcexport
avcimport
avctest
in /usr/local/bin
Importing areas...
Hi Kirk,
GRASS stuff.
- Shaun
build avce00?
Kirk,
-Shaun
Importing areas...
Kirk
grass5 mailing list
grass5@grass.itc.it
grass5 mailing list
grass5@grass.itc.it
grass5 mailing list
grass5@grass.itc.it
- Marvin
Kirk
Theory of the Universe
There is a theory which states that if ever anyone discovers exactly what the universe is for and why it is here, it will instantly disappear and be replaced by something even more bizarrely inexplicable. There is another theory which states that this has already happened.
-Hitchhiker's Guide to the Galaxy 2nd season intro
(oops, sorry for the repeated replies.)
First Pogril: Why is life like sticking your head in a bucket filled with hyena offal?
Second Pogril: I don't know. Why IS life like sticking your head in a bucket filled with hyena offal?
First Pogril: I don't know either. Wretched, isn't it?
-HitchHiker's Guide to the Galaxy
