Markus,
in "release_rules.txt" it says that one should install GDAL and copy it to the
GRASS binaries in /usr/local/grass5/lib. However, if one does a complete
reinstall on GRASS, there is no /usr/local/grass5 before doing a 'make
install' which is mentioned later in the text. Shouldn't this be the other way
around, i.e. make install and then installation of GDAL ?
Moritz
BTW, I get a warning at the very end of the compile process:
cp: cannot stat `src/scripts/shells/create_ipcs.sh': Aucun fichier ou
répertoire de ce type
chmod: getting attributes of `/home/grass/grass5.0.0pre1/dist.i686-pc-linux-gnu
/dev/create_ipcs.sh': Aucun fichier ou répertoire de ce type
This doesn't seem to cause a problem up to now, but what does this mean ?
P.S. Do you want this kind of questions / error message in grass5 or should I
post them to grass-bug ?
From neteler Wed May 23 16:46:44 2001
Return-Path: <neteler>
Received: by hgeo02.geog.uni-hannover.de (SMI-8.6/SMI-SVR4)
id QAA11953; Wed, 23 May 2001 16:46:44 +0100
Date: Wed, 23 May 2001 16:46:44 +0100
From: Markus Neteler <neteler@geog.uni-hannover.de>
To: grass5@geog.uni-hannover.de
Subject: Re: [GRASS5] instructions for making binaries
Message-ID: <20010523164644.A11891@hgeo02.geog.uni-hannover.de>
Mail-Followup-To: grass5@geog.uni-hannover.de
References: <E152a3M-0007ej-00@paf-linux.ulb.ac.be>
Mime-Version: 1.0
Content-Type: text/plain; charset=iso-8859-1
Content-Disposition: inline
Content-Transfer-Encoding: 8bit
User-Agent: Mutt/1.2.5i
In-Reply-To: <E152a3M-0007ej-00@paf-linux.ulb.ac.be>; from mlennert@ulb.ac.be on Wed, May 23, 2001 at 04:55:59PM +0200
Sender: grass5-admin@geog.uni-hannover.de
Errors-To: grass5-admin@geog.uni-hannover.de
X-BeenThere: grass5@geog.uni-hannover.de
X-Mailman-Version: 2.0.5
Precedence: bulk
List-Help: <mailto:grass5-request@geog.uni-hannover.de?subject=help>
List-Post: <mailto:grass5@geog.uni-hannover.de>
List-Subscribe: <http://www.geog.uni-hannover.de/mailman/listinfo/grass5>,
<mailto:grass5-request@geog.uni-hannover.de?subject=subscribe>
List-Id: GRASS 5 Developers mailing list <grass5.geog.uni-hannover.de>
List-Unsubscribe: <http://www.geog.uni-hannover.de/mailman/listinfo/grass5>,
<mailto:grass5-request@geog.uni-hannover.de?subject=unsubscribe>
List-Archive: <http://www.geog.uni-hannover.de/pipermail/grass5/>
Status: O
Content-Length: 1272
Lines: 33
Moritz,
On Wed, May 23, 2001 at 04:55:59PM +0200, mlennert@ulb.ac.be wrote:
Markus,
thanks for the hint, that's right. For compilation libgdal is not required.
I will change the order in release_rules.txt.
/dev/create_ipcs.sh': Aucun fichier ou répertoire de ce typeThis doesn't seem to cause a problem up to now, but what does this mean ?
Mhhh. It shouldn't appear any more as create_ipcs.sh is removed and all
cp's as well. Somewhere we probably missed to remove it. When does it
appear?
Please to "grass5".
From neteler Wed May 23 16:53:40 2001
id QAA12049; Wed, 23 May 2001 16:53:40 +0100
Date: Wed, 23 May 2001 16:53:40 +0100
Message-ID: <20010523165339.C11891@hgeo02.geog.uni-hannover.de>
References: <E152a3M-0007ej-00@paf-linux.ulb.ac.be> <20010523164644.A11891@hgeo02.geog.uni-hannover.de>
Mime-Version: 1.0
In-Reply-To: <20010523164644.A11891@hgeo02.geog.uni-hannover.de>; from neteler@geog.uni-hannover.de on Wed, May 23, 2001 at 04:46:44PM +0100
Precedence: bulk
Status: O
Content-Length: 831
Lines: 25
Hi again,
appear?
o.k, I found it:
./src/CMD/generic/POST_INSTALL.sh
and have removed it. Glynn, shall we keep the create_fifos.sh there?
Moritz: Does it break the installation? Then we have to release pre2...
If it is just a warning, we can live with that.
Regards
