[GRASS5] is search working?
Are the search functions on the user and developer mailing lists working properly? I am looking for tips on adding attributes (something like add columns) to existing vector maps (I thought this was a job for v.digit) however, I keep getting the dreaded "no matching articles" returned.
Kirk
hallo
returned.
Kirk
I thing, that results from google are often better, then from the site search
:frowning:
for adding columns to the table see manual of db.execute
    echo "alter table vector_file add column column_name varchar(50)"|db.execute
Jachym
Jachym Cepicky
e-mail: jachym.cepicky@centrum.cz
URL: http://les-ejk.cz
GPG: http://www.fle.czu.cz/~jachym/gnupg_public_key/
working properly?
Yes, I think so:
http://grass.itc.it/searchgrass.php
Search: attributes
Restrict to: GRASS Developers Mailing list
-> Documents 1 - 10 of 835 matches.
Where did you try (URL?). It should be redirected to grass.itc.it.
returned.
Search for 'db.execute' :slight_smile:
http://grass.itc.it/grass60/manuals/html60_user/db.execute.html
  Add new column to attribute table:
  echo "ALTER TABLE roads ADD COLUMN length double" | db.execute
Hope this helps
On Wed, Apr 27, 2005 at 06:11:06PM +0200, Jachym Cepicky wrote:
hallo
> returned.
> Kirk
:frowning:
Oh, really? If so, how to improve the situation (I am no htdig expert)?
Suggestions more than welcome.
working properly?
Yes, I think so:
Search: attributes
Thanks Markus. I was going in through the community link, to mailing lists, then getting directed to:
http://grass.institutoecos.org.br/cgi-bin/htsearch
They seem to have some kind of server issue. I emailed the administrator about it.
returned.
Hope this helps
>>working properly?
>Yes, I think so:
> Search: attributes
Well, the idea of the implementation is that
requests are redirected to grass.itc.it (as htdig lives there).
I see the problem now when entering
but how did you get there?
>>>>working properly?
>>>Yes, I think so:
>>>Search: attributes
I pull up the GRASS site at:
then click the link to Community, which directs my browser to:
http://grass.itc.it/community/index.php
from there I go to Mailing lists, which takes me to:
http://grass.itc.it/community/support.php
So far fine.
From there, I clicked on the links 'GRASS user list archive (June
1996-today) under Archives, which directs to:
http://grass.institutoecos.org.br/grass-list/
or
Archives mirror, which directs to
http://news.gmane.org/gmane.comp.gis.grass.user
neither of which appear to be in working order.
Now I understand.
Suggestions
- "Full GRASS user list archive (1991-today)"
    http://grass.itc.it/pipermail/grassuser/
  is the *full* archive (the only one [1])
- above the table there is "Search these mailing lists"
Ok, I have restructured the table:
Please try again... (the grass.institutoecos.org.br I cannot solve,
but you can use our search engine).
[1] Time ago I have added all mails from the original CERL
    mailing lists and usenet period to our archive (except for spam)
    You may want to enjoy
    http://grass.itc.it/pipermail/grassuser/1991-December/013369.html
    The first user mail came from Italy then (hey!).
Thanks!
How about removing a column or changing a column name? I've tried:
> echo "ALTER TABLE table_name DROP COLUMN column_name double" | db.execute
and
  > echo "ALTER TABLE table_name CHANGE COLUMN old_column_name new_column_name double" | db.execute
with no success...
Kirk
> v.digit)
As others noted, use db.execute.
v.digit will let you specify & create a new table but not alter an
existing one. I think this could be changed but that's the way it is
now.
Hamish
now.
Hamish
In QGIS there is "Add column" button.
Radim
