Hello,
I have put online the alpha-2 sources of KerGIS, which now include all
the raster modules and all the sites modules (and the sites library in
its place). Complete list of available modules at the end of the
message.
This new snapshot include fixes (missing access.c for setup, compilation
warning on IRIX, a buffer overflow in v.digit) and further organization
of the _installed_ directory.
For people wanting to develop with KerGIS, there are two special
purpose sub-directories:
$GISBASE/usr/local Reserved for local site programs
$GISBASE/opt Reserved for third parties add-ons
KerGIS will not mess with these subdirectories. Conversely, no third
party shall mess up with the kernel i.e. KerGIS that is the rest of the
directory.
WARNING!!! The commands to the xdriver are still passed via fifos, so
you won't have a running monitor on plateforms that do not support fifos
(change to sockets is planned for June 2004).
Here is the list of libraries and programs in KerGIS as today:
lib/ibtree
lib/btree
lib/linkm
lib/segment
lib/gis
lib/D
lib/bitmap
lib/build
lib/coorcnv
lib/dig_atts
lib/digit
lib/digitizer
lib/display
lib/icon
lib/imagery
lib/lock
lib/proj
lib/raster
lib/rowio
lib/sites
lib/transform
lib/vask
lib/vector
bin/d.colormode
bin/d.colors
bin/d.colortable
bin/d.erase
bin/d.font
bin/d.frame
bin/d.label
bin/d.labels
bin/d.measure
bin/d.mon
bin/d.points
bin/d.rast
bin/d.rast.edit
bin/d.rast.num
bin/d.rast.zoom
bin/d.rgb
bin/d.save
bin/d.sites
bin/d.text
bin/d.vect
bin/d.what.rast
bin/d.what.vect
bin/d.where
bin/g.ask
bin/g.filename
bin/g.findfile
bin/g.gisenv
bin/g.help
bin/g.manual
bin/g.menu.region
bin/g.region
bin/g.setproj
bin/g.version
bin/gis
bin/manage
bin/ps.map
bin/r.buffer
bin/r.cats
bin/r.clump
bin/r.coin
bin/r.colors
bin/r.combine
bin/r.compress
bin/r.cross
bin/r.describe
bin/r.in.ascii
bin/r.in.ll
bin/r.in.poly
bin/r.info
bin/r.mapcalc
bin/r.mask.points
bin/r.mfilter
bin/r.out.ascii
bin/r.patch
bin/r.poly
bin/r.profile
bin/r.reclass
bin/r.support
bin/r.what
bin/s.in.ascii
bin/s.menu
bin/s.out.ascii
bin/v.alabel
bin/v.build
bin/v.clean
bin/v.cutter
bin/v.extract
bin/v.in.ascii
bin/v.out.ascii
bin/v.patch
bin/v.proj
bin/v.prune
bin/v.spag
bin/v.support
bin/v.to.rast
bin/v.to.sites
bin/v.transform
sbin/d.region
sbin/g.access
sbin/g.mapsets
sbin/ps.select
usr.bin/d.3d
usr.bin/d.geodesic
usr.bin/d.graph
usr.bin/d.grid
usr.bin/d.his
usr.bin/d.histogram
usr.bin/d.icons
usr.bin/d.legend
usr.bin/d.mapgraph
usr.bin/d.profile
usr.bin/d.rast.arrow
usr.bin/d.rhumbline
usr.bin/d.scale
usr.bin/d.title
usr.bin/g.tempfile
usr.bin/ps.icon
usr.bin/r.average
usr.bin/r.binfer
usr.bin/r.contour
usr.bin/r.cost
usr.bin/r.covar
usr.bin/r.digit
usr.bin/r.in.erdas
usr.bin/r.in.ppm
usr.bin/r.line
usr.bin/r.los
usr.bin/r.mode
usr.bin/r.neighbors
usr.bin/r.out.ppm
usr.bin/r.out.ppm3
usr.bin/r.out.rlc
usr.bin/r.out.tga
usr.bin/r.random
usr.bin/r.report
usr.bin/r.resample
usr.bin/r.rescale
usr.bin/r.rescale.eq
usr.bin/r.slope.aspect
usr.bin/r.stats
usr.bin/r.surf.contour
usr.bin/r.surf.idw
usr.bin/r.thin
usr.bin/r.transect
usr.bin/r.volume
usr.bin/r.watershed
usr.bin/r.weight
usr.bin/s.surf.idw
usr.bin/s.surf.tps
usr.bin/v.apply.census
usr.bin/v.area
usr.bin/v.cadlabel
usr.bin/v.digit
usr.bin/v.in.arc
usr.bin/v.in.dlg
usr.bin/v.in.dxf
usr.bin/v.in.tig
usr.bin/v.in.transects
usr.bin/v.mkgrid
usr.bin/v.out.arc
usr.bin/v.out.dxf
usr.bin/v.out.moss
usr.bin/v.stats
usr.sbin/d.ask
usr.sbin/d.menu
usr.X11/libexec/xdriver
Enjoy!
Thierry Laronde (Alceste) <tlaronde@polynum.org>
http://www.kergis.org/ | http://www.kergis.com/
Key fingerprint = 0FF7 E906 FBAF FE95 FD89 250D 52B1 AE95 6006 F40C
