[GRASS5] LANDSAT TM
Greetings,
I am a grass user, and i am developing a web based interface to grass
using CORBA under GPL.
The ultimate objective is to allow the web based java applet [similar to
the grass client] to be able to access a distributed grass database.
Your suggestions/advice is welcome at nadig@web.cs.ndsu.nodak.edu
I also have another question regarding importing LANDSAT TM images into a
grass database. does anyone know how to import TM images in the BSQ
format?
The i.tape.other and i.tape.tm would work only for tape devices?
thank you,
Rohit
subject 'unsubscribe grass5'
Hi Rohit,
if you have the possibility to switch your bands into ASCII-files it is
no problem with "r.in.arc "
for example: input=band1.asc output=band1
greetings
Elke
Rohit schrieb:
Greetings,
format?
thank you,
Rohit
