[GRASS5] Latest install steps for Grass on Cygwin needed.
Hello,
I am working on installing Grass 5.3 under Cygwin and cannot get the X
windows installation to work.
I also have some older Grass versions that do not work correctly and I would
like some help uninstalling these Grass Versions.
Could someone post some links to installing Grass 5.3 under Cygwin.
thanks
Stephen
Hello there
Are you using a recent version of Cygwin with the new X.org X server? If so make sure and install the XFree86 compatibility package (it is not done by default). What exactly is the problem?
rm -rf /usr/local/grass5
rm /usr/local/bin/grass5
check paths carefully but that should be all there is to it.
Some notes here:
http://www.geog.uni-hannover.de/grass/grass53/binary/mswindows_cygwin/
and also item 1 here:
http://www.geog.uni-hannover.de/grass/grass50/binary/windows_cygnus/cygwin_grass50bininstall.html
has the list of Cygwin packages you need to install, which is important.
Paul
Paul,
I got Grass53 to run using the following :
6.2.2 XFree86 multiwindow mode
In cygwin, launch the XFree86 server at Cygwin Bash prompt with:
export DISPLAY=127.0.0.1:0
XWin -multiwindow -clipboard &
Now the X Server is listening and will open X related windows in individual
windows. Then start GRASS as usual:
grass5
d.mon x0
d.mon sel=x0
tcltkgrass &
nviz elevation.dem vect=roads & ---> not working because I do not have this
dataset
This runs GRASS similar to a common MS-Windows application
I am using the "global" dataset for a tutorial and can not view the "eco"
raster dataset using the nviz command:
Running command: (I think)
nviz el=eco
results in the following error:
"The Dynamic link library cygXft-2.dll could not be found in hte specified
path."
I am guessing there is something wrong with my cygwin installation.
Stephen
----- Original Message -----
To: "Stephen Clark" <stephen.clark@focus.ca>
Cc: <grass5@grass.itc.it>
Sent: Friday, September 24, 2004 1:59 AM
Subject: Re: [GRASS5] Latest install steps for Grass on Cygwin needed.
Hello there
would
Some notes here:
Paul
grass5 mailing list
grass5@grass.itc.it
http://grass.itc.it/mailman/listinfo/grass5
Paul,
The links you list below are problematic. I don't know whether the server is
just down or the URL's have changed.
The parallel page on the grass.itc.it site is
http://grass.itc.it/grass50/binary/windows_cygnus/
However, this is years out of date. It is hard to distinguish what is still
relevant for GRASS 5.3 and what is not.
A more up-to-date page for Cygwin installation is found at
<http://grass.itc.it/grass57/binary/mswindows_cygwin/cygwin_grass.html&gt;
GRASS 5.7 installation instructions can be found nearby at
<http://grass.itc.it/grass57/binary/mswindows_cygwin/&gt;\.
Comparable installation instructions for 5.3 (without the Cygwin info) can
be found at
<http://grass.itc.it/grass53/binary/mswindows_cygwin/&gt;
Finally, I ran into a pretty good set of instructions for Cygwin, GRASS 5.3,
and GRASS 5.7 a month back and posted it on my web site.
<http://www.public.asu.edu/~cmbarton/grass.htm&gt;
I hope this is helpful.
There was some discussion recently about cleaning up some of the older
descriptions on the itc web site. Maybe we could ask for that again.
Michael Barton
On 9/24/04 1:59 AM, "Paul Kelly" <paul-grass@stjohnspoint.co.uk> wrote:
Hello there
Some notes here:
Bereich Geographie – Naturwissenschaftliche Fakultät – Leibniz Universität Hannover
ss50bininstall.html
Paul
______________________________
Michael Barton, Professor & Curator
School of Human Diversity and Social Change
Arizona State University
Tempe, AZ 85287-2402
USA
voice: 480-965-6262; fax: 480-965-7671
