[GRASS5] LD_LIBRARY_PATH modification in init.sh (?)
To work around some problems when having GRASS libs linked
into /usr/local/lib/ for GDAL compiled with new GRASS raster
support, I would like to propose a change for LD_LIBRARY_PATH_VAR
in 'init.sh':
cd grass57/lib/init/
diff -u -r1.44 init.sh
--- init.sh 21 May 2004 08:51:53 -0000 1.44
+++ init.sh 30 Jun 2004 08:25:19 -0000
@@ -151,7 +151,7 @@
if [ ! "$LD_LIBRARY_PATH_VAR" ] ; then
   LD_LIBRARY_PATH_VAR=$GISBASE/lib
else
- LD_LIBRARY_PATH_VAR=$LD_LIBRARY_PATH_VAR:$GISBASE/lib
+ LD_LIBRARY_PATH_VAR=$GISBASE/lib:$LD_LIBRARY_PATH_VAR
fi
export LD_LIBRARY_PATH_VAR
So, to first search the GRASS libs from the running version,
then other libs in the LD_LIBRARY_PATH[_VAR].
Are any side effects to be expected?
Hello Markus
in 'init.sh':
@@ -151,7 +151,7 @@
else
fi
I agree---it looks like a bug the way it is now. Can you change it in
5.3 (src/general/init/init.sh) as well?
Paul
On Wed, Jun 30, 2004 at 11:10:38AM +0100, Paul Kelly wrote:
Hello Markus
> in 'init.sh':
> @@ -151,7 +151,7 @@
> else
> fi
Paul
Updated in 5.3 and 5.7.
