I'm trying to write a lex/yacc parser for reading in reclass rules for a
new s.reclass. Having zero experience with lex and yacc, I'm having a
little trouble trying to figure out how to have it be in one of three
parse modes. I'll know when calling the parser, which mode I want.
Basically, the reclass rules will allow sites to be reclass via existing
category values, a decimal (double) attribute or a string attribute.
The rules can be like:
item = cat
item thru item = cat
item item [item ...] = cat
* = cat
The "*" is a default reclass rule, and is a singleton (if it is given).
So, a generic grammer...
rule: item '=' cat
| item "thru" item '=' cat
| item_list '=' cat
| '*' = cat
item_list: item
| item_list item
item: integer
| decimal
| string
One problem, is this grammar doesn't apparently restrict all items to
be the same type. So, perhaps I have four rule types (default_rule,
int_rule, decimal_rule, string_rule). I still need each parse line
to ensure the same type of rule is invoked. I'm not clear on how
one does that...
And, yes, I could write the parser w/o lex/yacc, but I'd like to use
them...
Eric G. Miller <egm2@jps.net>
item = cat
* = cat
rule: item '=' cat
| item_list '=' cat
| '*' = cat
item_list: item
| item_list item
This is ambiguous; "item = cat" could either match the first rule or,
given that a single item can be an item list, the third rule.
item: integer
| decimal
| string
one does that...
%token THRU
rule : integer '=' cat
| decimal '=' cat
| string '=' cat
| integer THRU integer '=' cat
| decimal THRU decimal '=' cat
| string THRU string '=' cat
| integer_list '=' cat
| decimal_list '=' cat
| string_list '=' cat
| '*' '=' cat
integer_list : integer integer
| integer integer_list
decimal_list : decimal decimal
| decimal decimal_list
string_list : string string
| string string_list
