[GRASS5] libgrass make errors..
I'm trying to build libgrass from CVS on RedHat 8.0 / intel / gcc 3.2 ..
Not sure where the libgrass-devel questions should go, sorry if this is the wrong place.
problem 1:
$ ./configure
$ make
Making all in gis
make[1]: Entering directory `/usr/src/grass/libgrass/gis'
/bin/sh ../libtool --mode=compile gcc -DHAVE_CONFIG_H -I. -I. -I. -g -O2 -c elist.c
libtool: ltconfig version `' does not match ltmain.sh version `1.3'
Fatal configuration error. See the libtool docs for more information.
make[1]: *** [elist.lo] Error 1
make[1]: Leaving directory `/usr/src/grass/libgrass/gis'
make: *** [all-recursive] Error 1
$ ./ltconfig --version
ltconfig (GNU libtool) 1.3 (1.385.2.117 1999/04/29 13:07:13)
Looking through ltmain.sh it is checking against v1.3, so I comment out the check and re-run ./configure and make.. which works until...
problem 2:
make
Making all in samples
make[1]: Entering directory `/usr/src/grass/libgrass/samples'
source='grassinfo.c' object='grassinfo.o' libtool=no \
depfile='.deps/grassinfo.Po' tmpdepfile='.deps/grassinfo.TPo' \
depmode=none /bin/sh ../depcomp \
gcc -DHAVE_CONFIG_H -I. -I. -I../gis -I../gis -g -O2 -c `test -f 'grassinfo.c' || echo './'`grassinfo.c
../depcomp: ../depcomp: No such file or directory
make[1]: *** [grassinfo.o] Error 127
make[1]: Leaving directory `/usr/src/grass/libgrass/samples'
$ which depcomp
/usr/bin/which: no depcomp in (...)
$ locate depcomp
/usr/share/automake-1.6/depcomp
/usr/share/automake-1.5/depcomp
$ ln -s /usr/share/automake-1.6/depcomp depcomp
$ make
make[1]: Leaving directory `/usr/src/grass/libgrass'
$ make install
  & successful install, but it took a while.
Hamish
