Hello
We have released LinGis 0.1 for SUSE Linux 9.1 today.
Description
LinGis is a distribution of free GIS applications and libraries in RPM
format, built for SUSE Linux 9.1 i386 in a similar way, as SUSE does it.
It's easy to install, as it can be handled by the Yast2 software
installation tool.
Installation
Follow these simple steps for an easy installion of the LinGIS
distribution:
- in the Yast2 "Software" section choose the button "Change
Source of Installation"
- select "Add" and then "CD" in the following window
- then a new item "LinGis" will appear in the selection area
- close the "Software Source Media" window with "Finish"
- choose "Install and Remove Software", back in the Yast2
Control Center
- pick "Selections" as Filter in the upper left corner
- in the list below you will find the entry "LinGis Applications", from
which you can select the applications and libraries you
want to install
- "Accept" will do the rest
Content
LinGis contains the following applications and libraries in their current
version:
GMT
cfitsio
dcmms
demeter
gdal (with patch for Grass 5.7 by Radim Blazek)
geos
grass50
grass53
grass57
jasper-uuid
libgeotiff
libjasper-uuid
mapserver
mixkit-devel
ogdi
openscenegraph
php-cgi
postarabic
postgis
postgis-lwgeom
proj
pysqlite
qgis
qslim
sdts++
shapelib
sqlite
thuban
vis5d+
demo-alaska
demo-frida
demo-mittelerde
maplab
phpPgAdmin
HDF
lapack
Download
The distribution is available as ISO image, or just the RPMs at the
following address:
ftp://ftp.lingis.org/lingis/
Bugs and Feedback
In case of problems or bugs please submit a bugreport at
http://www.lingis.org/bugzilla
Or write an email to
feedback@lingis.org
Have fun,
your LinGis Team
