recently I switched to KDE 1.1.2 (SuSe 7) and have the problem,
than the GRASS monitor does not refresh if hidden by another window
and put back into foreground. It remains black.
Does anyone have an idea how to fix this?
Thanks!
subject 'unsubscribe grass5'
Thanks!
It seems exposure events not being generated.
One trivial way could be to enable backing-store in the X server
(more memory needed by X)
In /etc/X11/xdm/Xserver
change a line like this
:0 local /usr/X11R6/bin/X
to
:0 local /usr/X11R6/bin/X -wm
Hope this help. Ciao
On Fri, Oct 13, 2000 at 04:19:53PM +0200, Roberto Micarelli wrote:
Markus Neteler wrote:
> Hi all,
> Thanks!
> Markus
to
The "backing-store" thing was the right idea. I had to
add
Option "backingstore" "on"
to the
Section "Device"
of /etc/X11/XF86Config as I am using Xfree4. Now it works o.k.
Thanks a lot
mhhh, it's still not perfect. At least the background is not copied into
the monitor any more but the contents (site list crosses) still
dissappear.
I will try your -wm now...
> > Hi all,
> > Thanks!
> > Markus
> to
add
to the
Section "Device"
Thanks a lot
