[GRASS5] List of compile warnings
Hi developers,
using the CRAY compiler (maybe the -Wall would do the same) I
have generated a list of compile warnings in CVS:
cvs up documents/compile_warnings.log
Originally it contained 354 warnings, I have fixed a lot (and thrown out the
qsort warnings) and would leave the others for you :slight_smile: (142 to go).
A few problems a looking severe.
Procedure: If you fix one or more warnings, please eliminate from
the list in CVS. Hope we get this list to a minimum. The CVS obviously
accepts donations, the commit mailing list is not fed at time.
subject 'unsubscribe grass5'
Mostly either qsort() or signed/unsigned char* mismatch, with a couple
of other function pointer mismatches (basically the same issue as for
qsort). As for the rest:
* src/libes/vask/V_tty.c:
This is using a function returning "int" as a signal handler; on
GNU/Linux (at least), signal handlers return void. This could be an
issue on certain platforms (specifically, if a return value is pushed
onto the stack, or stored in a register which is assumed to be
unmodified by the call).
Aside: is use of signal() a good idea? Is it meant to be the BSD or
SysV version? Should sigaction() be used instead?
* src/misc/m.kappa/cmd/readin_data.c:
This treats "mat" as "int**", but mkappa.h indicates that it is
"long**". The second G_malloc needs to allocate "ncat * sizeof (long)"
bytes, and the fscanf should be using "%ld", not "%d". This will be a
problem if sizeof(int) != sizeof(long).
* src/display/devices/lib/socket.new/SWITCHER.c:
The explicit cast to (unsigned int *) is redundant; the parameter is
an "int*" like the (uncast) argument.
* src/ps.map/ps.map/cmd/vect.c:
    l = LENGTH ( dx, dy );
    if ( l == 0){
    *x = 5 / 0;
    *x = dx/l;
    *y = dy/l;
WTF?
Fix: choice of (0,0), (NaN,NaN), raise(SIGFPE), something else?
* src/raster/r.infer/cmd/infer.h:
Redefines "TRUE" and "FALSE", which are already defined in gis.h.
Harmless, but should probably be removed.
* src/raster/r.surf.idw/cmd/main.c:
Using comments to disable code containing comments:
    /*nbr_head->distance = maxdist;
    nbr_head->searchptr = &(nbr_head->Mptr); /* see replace_neighbor */
Fix: don't use comments to disable code; use "#ifdef notdef ... #endif".
Also, it's not immediately clear as to whether both lines were meant
to be disabled, or just the first one.
* src/sites/cdhc/as181.c:
These are real errors; pointer to double being passed where a double
is expected (eps) and vice-versa (w, p).
* src/sites/s.to.rast/main.c:
Compiler moaning about valid code:
    default: /* Should never happen */
Workaround: add a "break".
* src/libes/libimage/open.c:
cvtshorts() expects "register unsigned short buffer" (which means
what, exactly? an array of register variables?) but cvtimage() is
passing "register long buffer". It appears that "buffer" is actually
mixed shorts/longs (I think that, by "long", the author means "32-bit
integer"). I still think that this is a real error, though.
Aside: someone should just remove all references to "register" from
this code; it doesn't seem to make much sense in the context of
function parameters.
* src.contrib/SDTS/mapdev/v.out.sdts/spatial_ref.c:
Takes a parameter of type "struct Map_info" (defined in
"d.what.vect/cmd/what.h", which it doesn't include). It never actually
uses this parameter, though.
* src.contrib/SDTS/mapdev/v.in.sdts/<something>:
Some file (the message doesn't say) includes the header
src.contrib/SDTS/libes/fips123/f123inc/stc123.h, which defines
"MAXINT" as "32767L". However, GNU libc defines this (in values.h) as
an alias for "INT_MAX".
Fix: change the name, or use "SHRT_MAX" (from limits.h).
