Hi 2 all,
while reworking the test suite (dejagnu) (should work now) i found some
modules not reacting correctly to the "help" parameter on command line.
I added these modules with a short description to the BUGS file.
Some modules do produce "garbage" output with the
"--interface-description" flag, which makes the output fail parsing with
a xml parser. For your information here the list of modules:
{m.lulc.USGS} {Mlulc.read} {Mlulc.USGS} {v.surf.rst} {v.out.atlas}
{v.in.dxf2} {v.in.dxf} {v.in.atlas} {s.surf.rst} {r.weighted.cn}
{r.resamp.rst} {r.random} {r.out.rlc} {r.mapcalc} {r.flow} {r.colors}
{m.in.stf1.db3} {m.in.pl94.db3} {i.tape.mss.h} {i.gensigset} {g.list}
{d.where} {d.rhumbline} {d.paint.labels} {d.colormode}
(sorry, as tcl-list structure).
The testsuite will produce an additional file "modules-list.html" in the
documents dir with a summary of the status of all modules (not perfectly
formatted). The first status field is generated from the
list5_of_modules.txt file, which can be modified by hand to reflect
differences from the automated tests.
cu,
Andreas
Andreas Lange, 65187 Wiesbaden, Germany, Tel. +49 611 807850
Andreas.Lange@Rhein-Main.de - A.C.Lange@GMX.net
subject 'unsubscribe grass5'
