[GRASS5] Looking for ncurses code
  Please, someone, point me to the directory containing the ncurses code
interface. Again, I'm looking through directories, but I don't find just
where it's stored.
  I've set myself the task of re-writing the CLI using the latest
ncurses-5.x and taking advantage of the panels, forms and menus. I also want
to expand the variable sizes for the data directory fields to accommodate
more than 14 chars.
  This new interface will not be added to the CVS repository. I'm doing it
for me. Of course, once I get it all working -- and looking the way I want
it to look -- I'll make it available as a separate module for anyone who
wants it.
Rich
Dr. Richard B. Shepard, President
                       Applied Ecosystem Services, Inc. (TM)
              Making environmentally-responsible mining happen. (SM)
            2404 SW 22nd Street | Troutdale, OR 97060-1247 | U.S.A.
+ 1 503-667-4517 (voice) | + 1 503-667-8863 (fax) | rshepard@appl-ecosys.com
subject 'unsubscribe grass5'
Rich,
where it's stored.
it is in src/libes/vask/
Mhhh, what is "CLI"?
more than 14 chars.
wants it.
Rich
  Thank you.
  Command Line Interface. As opposed to tcl/tk and other GUI (Graphic User
Interfaces). That's what we see when we start GRASS in "text" mode.
Rich
  Thank you.
I see (just the abbreviation was unclear to me).
You can see CLI at work in src/raster/r.agnps50/ if you need an
example.
example.
  Again, thanks, Markus.
  I've grep'd the files in src/libes/vask/ and haven't found the names of
the variables used to store the input (GISDBASE. location and mapset). Is
there any guide in the programmer's manual to the organization of the start
up code and the user interface? I don't recall seeing that the last time I
looked.
  I'll look at the tcl/tk code, too, and see if I can find these variable
names there.
Rich
> example.
looked.
The vask library is just a simplified wrapper for curses. The GISDBASE,
LOCATION and MAPSET are written to the ~/.grassrc5 file. If you're
interested in the session start-up code, have a look in
src/general/init/, which among other things sets the environment
variables above. Also good to poke around src/libes/gis/ to see how
many things are handled regarding database management, I/O, etc... Don't
rely on the Programming manual. It's helpful, but doesn't document a
lot of stuff (some things just aren't documented).
names there.
It gets them from the environment...
Eric G. Miller <egm2@jps.net>
  Thank you, Eric. That's just the information I need.
Rich
> > example.
> looked.
We should collect the missing stuff in a Programming manual "TODO".
Please send input or directly feed the
progmangrass50/TODO
(outside GRASS source code, inside CVS)
> names there.
They are documented/listed here:
documents/envVars.txt
