[GRASS5] m.in.e00 status, project
I am a land use planner in Massachusetts interested in expanding the use of
GRASS by municipal public planners. Our state has a very good GIS
department, but everything is available only in .e00 or ESRI shapefile
format (see http://www.state.ma.us/mgis/database.htm for examples).
The burden of having to convert this data to GRASS might prevent people from
otherwise seeing the exciting potential of this open source resource, so I'd
like to work with the State to offer a CD with all the layers already
converted.
At present, what is the state of m.in.e00 and other conversion options?
Should I be using 5.x instead of 4.3? Please advise.
Ezra Glenn
Environmental & Land Use Planner
McGregor & Associates
60 Temple Place, Suite 410
Boston, MA 02111
email: eglenn@mcgregorlaw.com
phone: 617-338-6464 x18
fax: 617-338-0737
From neteler Wed Jun 20 19:21:30 2001
Return-Path: <neteler>
Received: by hgeo02.geog.uni-hannover.de (SMI-8.6/SMI-SVR4)
  id TAA06617; Wed, 20 Jun 2001 19:21:29 +0100
Date: Wed, 20 Jun 2001 19:21:29 +0100
From: Markus Neteler <neteler@geog.uni-hannover.de>
To: Glynn Clements <glynn.clements@virgin.net>
Cc: grass5@geog.uni-hannover.de, Request Tracker <grass-bugs@intevation.de>
Subject: Re: [GRASS5] [bug #752] (grass) configure: doesn't add -lGL -lGLw -lGLUT entries in head file (Solaris)
Message-ID: <20010620192129.B6059@hgeo02.geog.uni-hannover.de>
Mail-Followup-To: Glynn Clements <glynn.clements@virgin.net>,
References: <20010612173505.465B113A00@mailman.intevation.de> <15142.23525.316240.636978@cerise.nosuchdomain.co.uk> <20010613152734.A10125@hgeo02.geog.uni-hannover.de> <15143.54194.830470.971544@cerise.nosuchdomain.co.uk>
Mime-Version: 1.0
Content-Type: text/plain; charset=us-ascii
Content-Disposition: inline
User-Agent: Mutt/1.2.5i
In-Reply-To: <15143.54194.830470.971544@cerise.nosuchdomain.co.uk>; from glynn.clements@virgin.net on Wed, Jun 13, 2001 at 09:57:22PM +0100
Sender: grass5-admin@geog.uni-hannover.de
Errors-To: grass5-admin@geog.uni-hannover.de
X-BeenThere: grass5@geog.uni-hannover.de
X-Mailman-Version: 2.0.5
Precedence: bulk
List-Help: <mailto:grass5-request@geog.uni-hannover.de?subject=help>
List-Post: <mailto:grass5@geog.uni-hannover.de>
List-Subscribe: <http://www.geog.uni-hannover.de/mailman/listinfo/grass5&gt;,
  <mailto:grass5-request@geog.uni-hannover.de?subject=subscribe>
List-Id: GRASS 5 Developers mailing list <grass5.geog.uni-hannover.de>
List-Unsubscribe: <http://www.geog.uni-hannover.de/mailman/listinfo/grass5&gt;,
  <mailto:grass5-request@geog.uni-hannover.de?subject=unsubscribe>
List-Archive: <http://www.geog.uni-hannover.de/pipermail/grass5/&gt;
Status: O
Content-Length: 2785
Lines: 75
On Wed, Jun 13, 2001 at 09:57:22PM +0100, Glynn Clements wrote:
Markus Neteler wrote:
> > > the "configure" doesn't add -lGL -lGLw -lGLUT in head file on Solaris/SUN
> > > while this is working on Linux. Similar was reported for MaxOSX recently.
> > > After adding above entries into head file, everything compiles fine.
> > > The libraries are detected:
> > > checking GL/gl.h and GL/GLwMDrawA.h... -I/usr/include -I/usr/local/include and -I/usr/include
> > > checking for glBegin in -lGL... (cached) no
> > > checking for gluBeginCurve in -lGLU... (cached) no
> > > checking for GLwDrawingAreaMakeCurrent in -lGLw... (cached) no
> > > checking for GLwCreateMDrawingArea in -lGLwM... (cached) no
> > > I have no idea how to fix this (as it works for Linux). Probably
> > > some wrong variable quoting?
> > What does config.log say?
> > After the line:
> > configure:4226: checking for glBegin in -lGL
> > there should be the compilation command, along with any error messages
> > and the source of the test program. The error message(s) should
> > provide some clues as to why it failed.
Of course, this was based upon the (mistaken) assumption that
configure actually performs the test ...
> It seems there is nothing:
> configure:4044: checking libpq paths
> configure:4059: checking for PQcmdTuples in -lpq
> configure:4183: checking GL/gl.h and GL/GLwMDrawA.h
> configure:4270: checking for gluBeginCurve in -lGLU
> configure:4314: checking for GLwDrawingAreaMakeCurrent in -lGLw
> configure:4354: checking for GLwCreateMDrawingArea in -lGLwM
> configure:4460: checking for sql.h
> configure:4496: checking for location of odbc lib
> configure:4594: checking for jpeglib.h
> (above of that the curses compile thing is present in config.log).
> Strange...
Not really; this is a consequence of configure's caching mechanism.
Do "rm config.cache", then re-run configure, then check again.
Better still, add the lines
     define([AC_CACHE_LOAD], )dnl
     define([AC_CACHE_SAVE], )dnl
to the beginning of configure.in (before the AC_INIT), run autoconf,
then commit both configure.in and configure to CVS.
This will completely disable autoconf's caching mechanism (which
basically causes humans to waste countless hours tracking down
problems in order to allow CPUs to spend more time idle; whoever
thought that this was a good idea deserves shooting; actually,
shooting is too good for them).
Glynn,
even if the cache is disabled, the libraries won't be added.
Seems to be a coding problem in configure.
From neteler Wed Jun 20 19:39:54 2001
  id TAA08992; Wed, 20 Jun 2001 19:39:54 +0100
Date: Wed, 20 Jun 2001 19:39:54 +0100
To: grass5 developers list <grass5@geog.uni-hannover.de>
Message-ID: <20010620193954.A8967@hgeo02.geog.uni-hannover.de>
Mail-Followup-To: grass5 developers list <grass5@geog.uni-hannover.de>
Mime-Version: 1.0
Subject: [GRASS5] GMATHLIB support improved
Precedence: bulk
Status: O
Content-Length: 607
Lines: 30
Hi developers,
I have cleaned up the spreaded numerical functions and moved
them all into GMATHLIB (src/libes/gmath).
Following modules are affected:
* r.surf.fractal
* r.surf.gauss
* r.surf.random
* i.cca
* i.pca
* i.zc
* i.fft
* i.shape (src.contrib/CERL/imagery/)
I have tested compilation on Linux, Solaris/SUN and CRAY. Please
report any functionality problems which may occur from (not)
externally declared variables.
Perhaps someone could clean the
src/libes/gmath/local_proto.h and
src/libes/gmath/numerical.h
(I am not too familiar with those declaration style).
From neteler Wed Jun 20 20:03:55 2001
  id UAA09112; Wed, 20 Jun 2001 20:03:55 +0100
Date: Wed, 20 Jun 2001 20:03:55 +0100
Message-ID: <20010620200355.B8967@hgeo02.geog.uni-hannover.de>
Mime-Version: 1.0
Subject: [GRASS5] d.rast, r.stats: G_percent bug
Precedence: bulk
Status: O
Content-Length: 300
Lines: 12
Hi again,
at time there is a little G_percent() mess with
d.rast -> doesn't reach 100% (in tcltkgrass)
r.stats -> displays percentage very odd, doesn't reach 100%
Does anyone have a suggestion to fix this? It seems that
my last tries in r.stats weren't successfull.
Thanks in advance,
From neteler Wed Jun 20 21:20:10 2001
  id VAA09694; Wed, 20 Jun 2001 21:20:10 +0100
Date: Wed, 20 Jun 2001 21:20:10 +0100
To: grass5@geog.uni-hannover.de
Subject: Re: [GRASS5] broken links in documentation and s.vol.rst
Message-ID: <20010620212010.C9402@hgeo02.geog.uni-hannover.de>
Mail-Followup-To: grass5@geog.uni-hannover.de
References: <F97OONwIidWZe2BS7QT0000e753@hotmail.com> <15133.33019.929881.777086@cerise.nosuchdomain.co.uk> <20010605194015.D23813@calico.local> <15133.41062.452043.244362@cerise.nosuchdomain.co.uk> <20010611144400.B23503@hgeo02.geog.uni-hannover.de> <3B2F7FC9.A51A2D23@unity.ncsu.edu>
Mime-Version: 1.0
In-Reply-To: <3B2F7FC9.A51A2D23@unity.ncsu.edu>; from hmitaso@unity.ncsu.edu on Tue, Jun 19, 2001 at 12:37:29PM -0400
Precedence: bulk
Status: O
Content-Length: 4292
Lines: 121
Helena,
On Tue, Jun 19, 2001 at 12:37:29PM -0400, Helena Mitasova wrote:
Markus,
maybe you can replace the outdated command list reference on grass
manual page with Eric's list - it is really useful both for new and
old users.
http://www.geog.uni-hannover.de/grass/gdp/html_grass5/grass_commandlist.html
o.k, done. I have been using Eric's version as I don't get g.xml2html
compiled at time. Perhaps Eric can update again the
html/grass_commandlist.html
as I have added the missing descriptions? The web site will get updated
by cron_job.
And here are the broken links
http://www.geog.uni-hannover.de/grass/grass5/related/README.mesa3d
(this link is called from
http://www.geog.uni-hannover.de/grass/grass5/binary/linux/REQUIREMENTS.html
fixed.
several links:
http://www.geog.uni-hannover.de/grass/gdp/html_grass5/programming/time/index.html
http://www.geog.uni-hannover.de/grass/gdp/html_grass5/programming/sites-api/index.html
http://www.geog.uni-hannover.de/grass/gdp/html_grass5/programming/raster/fpnv.html
http://www.geog.uni-hannover.de/grass/gdp/html_grass5/programming/g3d/index.html
called from
http://www.geog.uni-hannover.de/grass/grass5/index.html
all removed as these html pages are pretty outdated (use book instead).
Also please update:
http://www.geog.uni-hannover.de/grass/grid3d/index.html
it has a link to s.vol.rst binaries and says that sources won't be
distributed.
Changed.
As for s.vol.rst - it may actually be useful to include it into GRASS5 -
it can be run without the grid3 if it is run with the option of bivariate
interpolation with additional variable (for example precipitation with
influence of terrain). We just got a paper accepted about it to TGIS and
we say that it is available in GRASS5, so it would be nice to have it
there. It works very well and there aren't many programs around that can
do that. However, there is a problem with compilation without the g3d
library so I would have to take out all the volume stuff and we may end up
again with 2 versions of similar program. So I don't know, let me know
what do you think.
Well, at time I have
- retagged src/libes/g3d to the release_branch (although I dislike this due
   to the bugs)
- added s.vol.rst at
   src.contrib/GMSL/g3d/src3d/sites/s.vol.rst
So s.vol.rst can be compiled successfully. As the other g3d modules are
not present, the g3d lib shouldn't cause too much headaches at time.
Figure 4b and a related animation in the document
http://www2.gis.uiuc.edu:2280/modviz/viz/sinter.html
and
http://www2.gis.uiuc.edu:2280/modviz/viz/tropy.html
illustrates what the program does The input is 2D raster of elevation and
site precipitation and output is precipitation raster map. It can be used
also for other phenomena.
... they look nice!
Thanks for contributing s.vol.rst!
> On Wed, Jun 06, 2001 at 04:15:50AM +0100, Glynn Clements wrote:
> > Anyway, all of this is moot unless g3d finds its way back into the
> > source tree.
> > So, should I get rid of the GLw checks altogether? Or is g3d's absence
> > likely to be only temporary?
> Glynn,
> this g3d absence *is* only temporary unless the bugs are fixed. Jaro
> Hofierka offered to look into them, probably he will find the time.
> Or, Helena, could you provide some help?
> Basic bug is the 3D coordinates system confusion: The 3D coordinates system
> should be similar to GRASS 2D, just with a 3rd dimension. At time some
> modules read bottom-up, other top-down etc. Maybe much of the problems
> can be cleaned out without too much work, only someone has to fully
> understand the g3d concept.
> Markus
> grass5 mailing list
grass5 mailing list
Markus Neteler * University of Hannover
Institute of Physical Geography and Landscape Ecology
Schneiderberg 50 * D-30167 Hannover * Germany
Tel: ++49-(0)511-762-4494 Fax: -3984
converted.
m.in.e00 seems to be working well whereas a v.in.shape is a little more
troublesome. Neither have any concept of checking projection/datum
stuff. One thing to note, is attribute support for vectors in GRASS is
fairly weak. The infrastructure is coming along with dbmi, but the
system is not as easy to utilize in the vector realm. Raster support,
is very good (I'm tempted to say it's superior in some ways to ESRI's
offerings ;). It can be very useful for analyzing slopes, erosion, line
of sight. I'd be less inclined to use it for maintaining parcel maps,
utilities, etc. Map making facilities are less than what can be done
with Arc/Info, as well.
Small Inquiry: If there was a non-profit foundation supporting GRASS
developers (i.e. professional programmers), do you think local
governments would be interested in funding development tasks? Being
that GIS is somewhat of a niche market, it's fairly difficult to attract
many Free Software developers. So, I've pondered the idea that a
foundation might make an appropriate conduit whereby public and private
entities could make "donations" or even enter into contracts for
specific work. When completed, such things would be released as free
software, so the GIS community as a whole could benefit and possibly
even avoid some of the ESRI tax ;). As it is now, even if someone wants
to make a donation for development work, there is no mechanism. Just a
thought...
(Note: All comments reference 5.0. It's mostly usable (some bugs here
and there) but Markus claims it is much better than 4.x. I can't
compare myself, but I've done some modelling/visualization with GRASS
that I was unable to do with Arc/Info GRID or ArcView's 3d Analyst/Spatial
Analyst packages.)
Eric G. Miller <egm2@jps.net>
From neteler Thu Jun 21 08:34:21 2001
  id IAA16264; Thu, 21 Jun 2001 08:34:21 +0100
Date: Thu, 21 Jun 2001 08:34:21 +0100
Cc: "Eric G. Miller" <egm2@jps.net>
Message-ID: <20010621083421.I10015@hgeo02.geog.uni-hannover.de>
Mail-Followup-To: grass5@geog.uni-hannover.de,
References: <F97OONwIidWZe2BS7QT0000e753@hotmail.com> <15133.33019.929881.777086@cerise.nosuchdomain.co.uk> <20010605194015.D23813@calico.local> <15133.41062.452043.244362@cerise.nosuchdomain.co.uk> <20010611144400.B23503@hgeo02.geog.uni-hannover.de> <3B2F7FC9.A51A2D23@unity.ncsu.edu> <20010620212010.C9402@hgeo02.geog.uni-hannover.de> <20010620185133.B5949@calico.local>
Mime-Version: 1.0
In-Reply-To: <20010620185133.B5949@calico.local>; from egm2@jps.net on Wed, Jun 20, 2001 at 06:51:33PM -0700
Precedence: bulk
Status: O
Content-Length: 1236
Lines: 37
On Wed, Jun 20, 2001 at 06:51:33PM -0700, Eric G. Miller wrote:
On Wed, Jun 20, 2001 at 09:20:10PM +0100, Markus Neteler wrote:
> Helena,
> > Markus,
> > old users.
> by cron_job.
I'll try to get them updated tonight. I can't guarantee I'll keep those
pages up forever. I want to look at using xsl stylesheets for
generating the output as it should be easier to tweak the looks and a
small perl script can probably do the job. At present I know 1.0e-19
about xslt, though ;0
Hi Eric,
it would be perfect to update them in CVS (only?):
Then it appears on the web automagically.
Thanks in advance,
developers (i.e. professional programmers), do you think local governments
Eric,
  Why not submit a proposal to the Gates foundation?
Rich
Dr. Richard B. Shepard, President
                       Applied Ecosystem Services, Inc. (TM)
            2404 SW 22nd Street | Troutdale, OR 97060-1247 | U.S.A.
+ 1 503-667-4517 (voice) | + 1 503-667-8863 (fax) | rshepard@appl-ecosys.com
                 Making environmentally-responsible mining happen.
Rich,
LMAO....
Bruce
Eric,
Rich
grass5 mailing list
Maybe.
Actually the German Grass User Group (GAV)
www.grass-verein.de (pages in German) is a non-profit which
can receive donations. It would be possible to even contract developers
if we get donations which are high enough. As a German citizen or
company it is easy to donate money tax-deducible to us.
Being that GIS is somewhat of a niche market,
it's fairly difficult to attract many Free Software developers.
The GIS market is bigger than you think IMO.
Actually we have attracted quite a few Free Software developers
and the number is rising which is also due to the publicity
of the FreeGIS project.
specific work.
If you want to contract somebody, there are companies and developers
available for work on Free Software. Intevation GmbH happens to be one.
We want to convince clients to actually do this.
ImageLinks is partly funded by US government to work on Ossim, btw.
And Intevation was also contracted several times to do Free GIS
software. www.mapit.de/index.en.html is one small example.
thought...
There are some mechanisms already in place.
Have you read: http://www.geog.uni-hannover.de/grass/commercial.html
  Bernhard
Professional Service around Free Software (intevation.net)
The FreeGIS Project (freegis.org)
FSF Europe (fsfeurope.org)
On Thu, Jun 21, 2001 at 02:48:04PM -0500, B. Byars wrote:
LMAO....
Probably not even a bad idea. >;-)
