Greetings all,
I am trying convert some Albers Equal Area coordinates to UTM coordinates, as I did with Grass Beta 11 and perhaps with earlier builds (beta 8?).
It seems as I am doing everything the same way I did with Beta 11, and yet I am getting slightly different results with Pre 4 then I did with Beta 11.
I entered all of the same projection values as I did before, and when I attempt to convert the same values I converted with Beta 11, I get results in the Y within 0.7 meters, and the X is off by about 510 meters. I get similar results with adjacent coordinates being off by a slight amount positively or negatively based on the direction traversed from the first test point.
All of the coordinates that I converted with Beta 11 are on the money, and I need to convert some more because of a data loss.
It seems like it must be a datum shift or some slight difference in the ellipsoid parameters.
Following are the projection parameters I am using:
m.proj2 inproj="+proj=aea +a=6378206.4 +es=0.0067686580 +lat_0=0.0000000000 +lat_1=34.0000000000 +lat_2=40.5000000000 +lon_0=-120.0000000000 +x_0=0.0000000000 +y_0=-4000000.0000000000 +unfact=1.0000000000" outproj="+proj=utm +a=6378206.4 +es=0.0067686580 +zone=11 +unfact=1.0000000000" input=test.coord output=results.coord
These are the AEA coordinates (in test.coord):
54460.32787477583042 -28942.57618516702496
43488.83566543841880 -29097.67753145935785
Which with Pre4 is converts to:
290240.740383 4181213.128503
279250.751623 4181409.678191
The values that Beta 11 correctly converted from the same AEA coords above are:
289729.04706660 4181213.82628647
278734.48157092 4181410.37628647
The values that Beta 11 converted are exactly aligned with other outside data sources.
Note that I used m.proj in beta 11, entered the same values in Pre 4 with m.proj to get the syntax for the proj2 call above. In Pre 4, both proj and proj2 give me the values which are slightly off from old successful conversions.
Am I just missing something? I greatly appreciate any help.
Here are the parameters I originally used in beta 11 (and in my Pre 4 attempts):
Coordinate Conversions
1- Conversion 2- Input/Output Selection
3- QuitEnter your selection [3] : 1
Initializing INPUT PROJECTION:
Please specify projection name
Enter 'list' for the list of available projections
Hit RETURN to cancel request
>aeaInitializing INPUT projection ELLIPSOID:
Please specify ellipsoid name
Enter 'list' for the list of available ellipsoids
>clark66Enter INPUT Central Parallel [lat_0] (23N) : 0
Enter INPUT First Standard Parallel [lat_1] (29:30N) : 34.0
Enter INPUT Second Standard Parallel [lat_2] (45:30N) : 40.5
Enter INPUT Central Meridian [lon_0] (96W) : -120
Enter INPUT False Easting [x_0] (0.000000) :
Enter INPUT False Northing [y_0] (0.000000) : -4000000.0
Enter plural for INPUT units [meters]:Parameters used in INPUT projection:
+proj=aea +a=6378206.4000000004 +es=0.0067686580 +lat_0=0.0000000000 +lat_1=34.0000000000 +lat_2=40.5000000000 +lon_0=-120.0000000000 +x_0=0.0000000000 +y_0=-4000000.0000000000 +unfact=1.0000000000Initializing OUTPUT PROJECTION:
>utmInitializing OUTPUT projection ELLIPSOID:
>clark66Enter OUTPUT Projection Zone [zone] : 11
OUTPUT Projection: Would you like to use South Hemisphere (y/[n]) ?
Enter plural for OUTPUT units [meters]:Parameters used in OUTPUT projection:
+proj=utm +a=6378206.4000000004 +es=0.0067686580 +zone=11 +unfact=1.0000000000Coordinate Conversions
Coord->Lat/Long Conversion
With thanks,
Jeshua Lacock __________________________
Programmer/Owner Phone: 760.935.4736
http://OpenOSX.com Fax: 760.935.4845
-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_
