[GRASS5] Mac OS X errors
Greetings,
I just compiled beta 11 on Mac OS X and here are the errors from modules tat I could not figure out (most of these errors have been posted before with previous builds):
The following modules: d.colors, i.class, i.ortho.photo, i.points, i.points3, i.vpoints, get this error:
   /usr/bin/ld: Undefined symbols:
   _gtty
   _stty
src/mapdev/v.in.shape:
   shp2dig.c:25: header file 'malloc.h' not found
I got this module compiled before (beta 10) by using:
Copying /System/Library/Frameworks/System.framework/Versions/B/Headers/bsd/sys/malloc.h to src/include.
Now I get the errors:
malloc.h:257: undefined type, found `u_short'
malloc.h:258: undefined type, found `u_short'
The same thing goes for these modules:
v.mkgrid, v.out.shape, src.contrib/SDTS
src/mapdev/v.rmdup:
   rmdup.c:201: structure has no member named `_shortbuf'
   make[1]: *** [OBJ.powerpc-apple-darwin1.2/rmdup.o] Error 1
   make: *** [all] Error 2
src/raster/r.in.gdal:
   I can't get the gdal lib compiled.
src/raster/r.in.png & src/raster/r.out.png:
   pngfunc.h:12: header file 'pnm.h' not found
   pngfunc.h:29: undefined type, found `xel'
   r.in.png.c:197: undefined type, found `pixel'
   r.in.png.c:200: undefined type, found `pixel'
   r.in.png.c:207: undefined type, found `pixel'
I think it's because I couldn't get netpbm compiled.
src/raster/r.in.random and src/sites/s.kcv:
   _lrand48
   _srand48
src/sites/s.random:
   main.c: In function `main':
   main.c:128: `drand48' undeclared (first use in this function)
   main.c:128: (Each undeclared identifier is reported only once
   main.c:128: for each function it appears in.)
   make: *** [OBJ.powerpc-apple-darwin1.2/main.o] Error 1
src/raster/r.mapcalc:
   _drand48
   make[1]: *** [/usr/src/grass5/dist.powerpc-apple-darwin1.2/etc/bin/cmd/r.mapcalc] Error 1
Markus said:
You should have in head file:
XCFLAGS = -I/usr/X11R6/include
I do have that in the head file, and I still get the error:
src.contrib/GMSL/NVIZ2.2:
   _XKillClient
   _XSetCloseDownMode
   _XSetRGBColormaps
   _XAllocColorCells
   _XStoreColors
   make[1]: *** [nvwish] Error 1
   make: *** [nvwish] Error 2
src.garden/answers/src.answers/raster/r.fill.dir:
   Needs fortran??
/usr/src/grass5.0beta11pre1/src.contrib/GMSL/g3d/src3d/raster/r3.showdspf.openGL
     mkdir OBJ.powerpc-apple-darwin1.2
     make -f OBJ.powerpc-apple-darwin1.2/make.rules
   cc -g -O2 -I/usr/src/grass5/src/libes/dspf -I/usr/src/grass5/src/libes/ogsf -I/usr/local/include/GL -I/usr/X11R6/include/GL -I/usr/X11R6/include -I/usr/src/grass5/src/include -c new_init_graphics.c -o OBJ.powerpc-apple-darwin1.2/new_init_graphics.o
   new_init_graphics.c:16: header file 'Xm/Xm.h' not found
   new_init_graphics.c:17: header file 'Xm/Form.h' not found
   new_init_graphics.c:19: header file 'GLwMDrawA.h' not found
   kns_defines.h:4: undefined type, found `GLXContext'
   kns_defines.h:5: undefined type, found `Window'
   kns_defines.h:6: undefined type, found `Widget'
   kns_globals.h:14: undefined type, found `XtAppContext'
Note that I had to issue a "make real-install" for it to install; "make install" seemed to do nothing.
Jeshua Lacock
Cartographer/Owner
http://SierraMaps.com
http://3dTopoMaps.com
Telephone: (760) 935-4481
subject 'unsubscribe grass5'
Jeshua,
thanks for your comprehensive compile test.
On Fri, Jan 26, 2001 at 12:44:01AM -0800, Jeshua Lacock wrote:
src/mapdev/v.rmdup:
I have updated this file, please
cvs update src/mapdev/v.rmdup
I changed the macro to:
defined(__APPLE__)
if it runs o.k., we can use it for several other errors as well.
So please try to compile the updated v.rmdup.
Hi again, Jeshua,
Greetings,
   _gtty
   _stty
no idea...
mh, no idea as well.
src/mapdev/v.rmdup:
Fixed.
Andreas, still the header files are not yet uploaded as I
have lost your tarball mail.
   _lrand48
   _srand48
fixed both r.random and s.kcv with defined(__APPLE__)
src/sites/s.random:
fixed with defined(__APPLE__)
   _drand48
fixed as well:
src.contrib/GMSL/g3d/src3d/raster/r3.mapcalc/mapcalc/xrand.c
> Markus said:
> You should have in head file:> XCFLAGS = -I/usr/X11R6/include
   _XKillClient
   _XSetCloseDownMode
   _XSetRGBColormaps
   _XAllocColorCells
   _XStoreColors
sorry, no idea.
   Needs fortran??
Yes, but port to C is on the way.
You need "lesstif" to be installed (MOTIF clone, see REQUIREMENTS).
That's strange and not o.k. (hi Justin :slight_smile:
So far my comments,
you may update and try the fixed modules.
Greetings,
Jeshua
I have changed the #includes to stdlib.h which is probably OK on Mac OS
X in v.in.shape, v.out.shape and v.mkgrid, and should #include malloc.h
on other systems. Hopefully they will compile OK now.
David
> Greetings,
Jeshua
If this fix is o.k., here is a list of other modules which might have
the same problem (sorry, no time to fix it):
find . -name '*.[hc]' -exec grep -l malloc.h {} \;
./src/include/std_incs.h
./src/libes/vect32_64/shapelib-1.2.8/shapefil.h
./src/mapdev/v.in.shape/cleanup.c
./src/mapdev/v.in.shape/shapefil.h
./src/mapdev/v.out.shape/shapefil.h
./src/sites/s.in.shape/cmd/shapefil.h
./src/sites/s.in.dbf/shapefil.h
./src.contrib/CERL/raster/r.hydro.CASC2D/all.h
./src.contrib/CERL/sites/s.surf.krig/nrutil.c
./src.contrib/SDTS/mapdev/v.in.sdts/att_ff_info.c
./src.garden/grass.postgresql/pg.in.dbf/shapefil.h
./src.garden/grass.postgresql/v.in.arc.pg/shapefil.h
./src.garden/grass.postgresql/v.in.shape.pg/cleanup.c
./src.garden/grass.postgresql/v.in.shape.pg/shapefil.h
./src.garden/grass.postgresql/v.in.shape.pg/shp2dig.c
> > Greetings,
> Jeshua
OK. I will look at those this evening. I think there is never any
problem with changing to stdlib.h because either it is necessary or it
#includes malloc.h anyway.
David
Hi Jeshua
Very strange - especially since "make" seems to work for you. Was there
any output when you tried "make install"? Or did it just seem to hang?
What happens if you remove the "@" sign before the if statement below
(the one above the ^ symbol)?
install:
   @ # The following action MUST be a single action. That is, all lines
   @ # except the last line must have a backslash (\) at the end to
   @ # continue the statement. The reason for this is that Make does not
   @ # have an exit command thus, exit terminates the shell. However,
   @ # Make creates a new shell for each action listed for a target.
   @ # Therefore, the only way exit will quit Make is if there is only
   @ # a single action for the target.
   @ # Check if grass has been compiled, if INST_DIR is writable, and if
   @ # grass is part of INST_DIR
   @ if [ ! -f ${GRASS_BIN}/grass${NAME_VER} ] ; then \
   ^ echo "ERROR: Grass has not been compiled. Try \"make\" first."; \
       echo " Installation aborted, exiting Make."; \
Is anything printed out if you try "make install" now? Finally if you
still don't see anything, then please send me your copy of your Makefile
(not Makefile.in).
Sincerely,
Jazzman (a.k.a. Justin Hickey) e-mail: jhickey@hpcc.nectec.or.th
High Performance Computing Center
National Electronics and Computer Technology Center (NECTEC)
Bangkok, Thailand
People who think they know everything are very irritating to those
of us who do. ---Anonymous
Jazz and Trek Rule!!!
