On Friday, January 26, 2001, at 01:36 AM, Markus Neteler wrote:
thanks for your comprehensive compile test.
On Fri, Jan 26, 2001 at 12:44:01AM -0800, Jeshua Lacock wrote:
> src/mapdev/v.rmdup:
> rmdup.c:201: structure has no member named `_shortbuf'
> make[1]: *** [OBJ.powerpc-apple-darwin1.2/rmdup.o] Error 1
> make: *** [all] Error 2I have updated this file, please
cvs update src/mapdev/v.rmdupI changed the macro to:
defined(__APPLE__)if it runs o.k., we can use it for several other errors as well.
So please try to compile the updated v.rmdup.
Markus,
Thanks for your brilliance! That does the trick.
Let me know when I should update the other (similar) modules.
Jeshua Lacock
Cartographer/Owner
http://SierraMaps.com
http://3dTopoMaps.com
Telephone: (760) 935-4481
subject 'unsubscribe grass5'
