On Wednesday, November 22, 2000, at 11:43 PM, Justin Hickey wrote:
> > > Sorry, </usr/local/grass-5.0b/dev/fifo.1a> not available
> > > Have GRASS administrator check etc/monitorcap file
> > > What other files might tcltkgrass may be dependent on??
> > Hmmm. Did you use the installation script grass5install.sh? This
> > script is supposed to create the fifos.
> Yessir! Uh-oh!
In that case, please do an ls -Fla in the directory
It should look something like this:
prw-rw-rw- 1 jhickey hpcc 0 Oct 9 11:53 fifo.17b|
prw-rw-rw- 1 jhickey hpcc 0 Oct 9 11:53 fifo.18a|
prw-rw-rw- 1 jhickey hpcc 0 Oct 9 11:53 fifo.18b|
prw-rw-rw- 1 jhickey hpcc 0 Oct 9 11:53 fifo.19a|
prw-rw-rw- 1 jhickey hpcc 0 Oct 9 11:53 fifo.19b|
prw-rw-rw- 1 jhickey hpcc 0 Oct 17 16:10 fifo.1a|
prw-rw-rw- 1 jhickey hpcc 0 Oct 17 16:10 fifo.1b|
If they do look like this, then compare the directory paths in
etc/monitorcap with /usr/local/grass-5.0b/dev/. They should be the same.
Thanks Justin! It turns out that (for whatever reason) grass was installed at /usr/local/grass5.
I made a symbolic link /usr/local/grass-5.0b -> /usr/local/grass5 and it works!!
(Markus: can you please add this to the installation instructions?: cd /usr/local; ln -s grass-5.0b grass5;)
Jeshua Lacock
Cartographer/Owner http://SierraMaps.com http://3dTopoMaps.com
Telephone: (760) 935-4481
subject 'unsubscribe grass5'
You're welcome.
and it works!!
Actually, we need to find where the grass-5.0b is coming from. We made a
decision that it would be grassx where x is the current major version
number to simplify coding and decrease user confusion.
Markus, do you know where the grass-5.0b is coming from?
Sincerely,
Jazzman (a.k.a. Justin Hickey) e-mail: jhickey@hpcc.nectec.or.th
High Performance Computing Center
National Electronics and Computer Technology Center (NECTEC)
Bangkok, Thailand
People who think they know everything are very irritating to those
of us who do. ---Anonymous
Jazz and Trek Rule!!!
and it works!!
Yes, however since nearly 2000 people have download the OS X binaries, I think it would be useful to add the symbolic link to the instructions until beta 9 is posted.
---------------------------------------- If you want to unsubscribe from GRASS Development Team mailing list write to:
>> /usr/local/grass5
>> and it works!!
>made a decision that it would be grassx where x is the current major
>version number to simplify coding and decrease user confusion.
Wow! 2000! Cool! In that case, yes you're right.
BTW, how did so many people find out about it so quickly? Do we have
2000 Mac users on the grasslist?
Sincerely,
Bangkok, Thailand
>> /usr/local/grass5
>> and it works!!
Justin,
I just sent out a few emails to mac news sites and Markus posted it on a GIS newsgroup...
On Thu, Nov 23, 2000 at 03:24:04PM +0700, Justin Hickey wrote:
Hi Jeshua
You're welcome.
> and it works!!
Huidae just fixed it in configure[.in]. Should be
/usr/local/grass5
now. We have to test this and maybe update INSTALL & friends.
Yours
>> and it works!!
Jeshua,
actually I don't understand the problem. We have a grass5b8_mac package
and a grass5install.sh script. The script takes care where to install
the package and generates the startup script depending on the install
path. This works since month.
Why this confusion?
Hi Jeshua
You're welcome.
> and it works!!
It's coming from PREFIX= in the configure script. You can change it with
--prefix=DIR. Changing the default to grass5 is a simple matter.
Eric G. Miller <egm2@jps.net>
>> and it works!!
Jeshua,
Why this confusion?
Markus,
That's all right, I don't understand either!! ;-D
All I know it that the GUI will not work unless this symbolic link is created....
>> >> and it works!!
>Jeshua,
>Why this confusion?
Markus,
created....
Could you do me the favor, remove the link and send the error
message? Then we might fix it (if something has to be fixed).
Thanks in advance
>> >> and it works!!
>Jeshua,
>Why this confusion?
Markus,
created....
Markus,
d.mon says:
And I get this error because grass is installed at/usr/local/grass5/...
>>/usr/local/grass5
>> >> >> and it works!!
>>from. We made a
>> >Jeshua,
>> >Why this confusion?
>> Markus,
>> created....
Markus,
d.mon says:
I see. The /usr/local/grass5/etc/monitorcap references the wrong
path. Please edit this file. Usually the settings are done on
compile time. With current CVS it should be o.k.
Hope this helps
(going to sleep now)
>>/usr/local/grass5
>> >> >> and it works!!
>>from. We made a
>> >Jeshua,
>> >Why this confusion?
>> Markus,
>> created....
Markus,
d.mon says:
Markus,
I can edit the file, but it will not help all of the people that downloaded the distribution. Until beta 9 is released the best fix (IMHO) is to create a symbolic link..
