Using the CVS version, I now get the following errors (I did not get these errors with beta 8):
GRASS 5.0beta9 > /usr/local/grass-5.0b/bin/tcltkgrass: cd: no such file or directory: /var/root/bin/powerpc-apple-macos [20]
/usr/local/grass-5.0b/bin/tcltkgrass: cd: no such file or directory: /var/root/bin [20]
/usr/local/grass-5.0b/bin/tcltkgrass: cd: no such file or directory: /usr/local/sbin [20]
Suggestions?
Thanks!
Jeshua Lacock
Cartographer/Owner http://SierraMaps.com http://3dTopoMaps.com
Telephone: (760) 935-4481
subject 'unsubscribe grass5'
/var/root/bin [20]
Suggestions?
What is happening here is that the tcltkgrass script is searching your
$PATH variable for Tk "wish" commands. In this case there are 3
directories defined in your path that do not exist on the system:
I don't think any harm is done, Grass still starts doesn't it? But if
you want to get rid of these messages, either create these directories
on your system, or remove them from your PATH variable.
Hope this helps.
Sincerely,
Jazzman (a.k.a. Justin Hickey) e-mail: jhickey@hpcc.nectec.or.th
High Performance Computing Center
National Electronics and Computer Technology Center (NECTEC)
Bangkok, Thailand
People who think they know everything are very irritating to those
of us who do. ---Anonymous
Jazz and Trek Rule!!!
On Tue, Nov 21, 2000 at 02:33:53PM +0700, Justin Hickey wrote:
Hi Jeshua
> /var/root/bin [20]
> Suggestions?
Hi Jeshua and Justin,
just checked in a fix to make "cd" quiet. Please test and
report...
cvs up src/tcltkgrass
cd src/tcltkgrass; gmake5
Hope this helps
