(looks like Lorenzo responded on the other list, but I'll expand on it a bit)
On a (standard) HFS+ file system, the Mac is _case-aware_, but not case-sensitive. (it stores filenames with case, but doesn't care). works in unicode too: á = Á, but á != a.
If the file system where the GRASS files are is UFS (not reccomended by most Mac users), it should be case-sensitive.
This creates porting problems sometimes, but these days I think most 'nix developers have taken care of it when it's an issue in the source (ie the source including different case-sensitive files, or trying to create them in compilation or when running). Then it's just up to non-Mac users to be aware of this (ie in your case trying to use both mask and MASK).
I'm a little confused here:
#Remove MASK:
GRASS 6.1.cvs (pat_gaussboaga):~ > g.remove MASK
REMOVE [MASK]
raster
header
category
color
history
misc
fcell MISSING
g3dcell MISSING
#create file with name 'mask' (but not MASK):
GRASS 6.1.cvs (pat_gaussboaga):~ > r.mapcalc "mask=if(isnull(po06_snow007),null(),1)"
100%
[Raster MASK present]
-> ouch.
did the mapcalc create 'MASK' or 'mask' at this point? That would be odd - it should create 'mask', since it's case-aware.
GRASS 6.1.cvs (pat_gaussboaga):~/0.875/SCRIPTS/geotop0.875 > g.copy mask,MASK
ERROR: <MASK> already exists
Is MacOSX unable to distinguish between mask and MASK?
Test in Linux:
GRASS 6.1.cvs (spearfish60):~ > r.mapcalc "mask=1"
100%
GRASS 6.1.cvs (spearfish60):~ > g.copy mask,MASK
COPY [mask@PERMANENT] to current mapset as [MASK]
raster
header
category
color MISSING
history
misc
fcell MISSING
g3dcell MISSING
-> works ok.
Surprised,
grass5 mailing list
grass5@grass.itc.it
http://grass.itc.it/mailman/listinfo/grass5
William Kyngesburye <kyngchaos@charter.net>
http://webpages.charter.net/kyngchaos/
"I ache, therefore I am. Or in my case - I am, therefore I ache."
- Marvin
