Helena,
thanks for the man-pages. I have created a new package
with lots of updates from Lisa and one more from me (d.mon):
http://www.geog.uni-hannover.de/grass/grass5/html_grass5/html_grass5.tar.gz
P.S. Markus - the Arcinfo and GRASS grid files are the same,
all you need to do is to replace the header - r.out.arc and
r.in.arc should just make it more convenient. We move
the grid files between Arcinfo/arcview/grass all the time
and it works fine and is very easy.
Sorry to insist, but this is surprising for me:
take a typical header:
ncols 101
nrows 161
xllcenter 4405975 -> lower left
yllcenter 5909975 -> lower left
cellsize 50.000000
NODATA_value -9999
Perhaps I am wrong that the order of cell rows in the file starts
with south row rather than north row in GRASS but on thursday I
had an ARC-GRID file which was flipped vertically after import.
I did not create this file but received it from someone else.
If I am wrong I will correct the r.out.arc of course. O.k. I will
check it with our local ARCView software. I did not take into account
that you could describe the lower left corner but start writing cell
values at upper left corner (someone missleading for me). I try
to find the ESRI reference.
Using GRASS is learning every day (in positive manner)
Best regards
If you want to unsubscribe from GRASS Development
Team internal mailing list write to:
subject 'unsubscribe grass5'
length: 1836
max: 0
