Paulick Consult wrote:
thank you very much for your help! The copy showed the following filenames:
/PERMANENT/DEFAULT_WIND
/PERMANENT/myname
/PERMANENT/PROJ_INFO
/PERMANENT/PROJ_UNITS
/PERMANENT/wind
After renaming to capital letters it worked as usual. Is there a
understandable reason why these two files and only those two changed to
minor letters?
It's the DOS 8.3 filename limit.
The default Linux mount options for VFAT (Win95) filesystems only
create an extended filename where necessary (i.e. longer than 8
characters, mixed case, contains spaces etc), otherwise they only
create a short filename. Short filenames don't preserve case; they are
always stored on disk using upper-case, but Linux treats them as lower
case (lower-case filenames are a lot more common).
You can change the behaviour with the "shortname" mount option:
shortname=[lower|win95|winnt|mixed]
Defines the behaviour for creation and display of filenames
which fit into 8.3 characters. If a long name for a file exists,
it will always be preferred display. There are four modes:
lower Force the short name to lower case upon display; store a
long name when the short name is not all upper case.
win95 Force the short name to upper case upon display; store a
winnt Display the shortname as is; store a long name when the
short name is not all lower case or all upper case.
mixed Display the short name as is; store a long name when the
More generally, don't "back up" Unix directories to a VFAT filesystem
by copying; create a tar file instead. Apart from issues of case,
copying to a VFAT filesystem will lose ownership, permissions, and
(some) timestamps, and won't handle links correctly.
