[GRASS5] masscomp display programs
i found by accident the directory src.contrib/NPS/GA1000 containing a
driver for the "Masscomp GA 1000 graphics display". Are there any
objections that i cvs-remove this directory?
If i get no feedback, i will cvs-remove the directory, as i think it is
of no use.
cu,
Andreas
Andreas Lange, 65187 Wiesbaden, Germany, Tel. +49 611 807850
Andreas.Lange@Rhein-Main.de, A.C.Lange@GMX.net
subject 'unsubscribe grass5'
On Sun, Jun 18, 2000 at 09:31:03PM +0200, Andreas Lange wrote:
of no use.
in my opinion it can be removed. Additionally the directories
src/display/devices
       4105
       IGRAPH
       IRIS (?)
       MASS
       SUNCORE
       SUNVIEW
may be removed.
From README:
Contents:
   MASS The MASSCOMP driver
   SUN The SUN color driver for SUN windows
   4105 For Tektronix 4105
   IGRAPH Intergraph driver
   IRIS IRIS Personal Workstation - Silicon Graphics
Andreas: I have a cvs.remove script which would simplify the remove
process. Of course it needs to be used carefully. If you want, I
can remove the stuff for you, if all agree.
Best wishes
markus
Hi Markus,
the IRIS driver should be removed too, it is for IRIX systems without
X11 (pre IRIX 4? don't know, that was long before my start with IRIX).
MASSCOMP, Tektronix and Intergraph are IMHO not used any more. Anyone
still using SunView with the SUN driver?
I would suggest that everyone who encounters obsolete code should post
to the list. There are for sure some more obsolete parts and with cvs
nothing is lost forever.
If you have a script to remove from cvs, go for it.
thank you,
Andreas
> Hi,
> of no use.
src/display/devices
       4105
       IGRAPH
       IRIS (?)
       MASS
       SUNCORE
       SUNVIEW
may be removed.
>From README:
Contents:
Best wishes
markus
