[GRASS5] Migration of GRASS Prog. manual into source code (doxygen)
Hi developers,
a student of our group, Paolo Armani, was so kind
to write a PERL script for migrating the Latex
code of the GRASS 5 Programmer's manual into doxygen
style. His script automatically
- changes Latex -> doxygen
  (using HTML tags, keeping Latex formula etc)
- searches the function in the GRASS libes directories
- inserts the modified doxygen description on top of
  each function into the related source code file(s).
- works recursively in src/libes/
Example:
------------- Latex source code -------------
\Gfunc{int}{G\_read\_history (char *name, char *mapset, struct History
  *history)}{read raster history file}{This routine reads the history file for
  the raster file \textbf{name} in \textbf{mapset} into the \textbf{history}
  structure.
  A diagnostic message is printed and -1 is returned if there is an error
  reading the history file. Otherwise, 0 is returned.}
------------- End Latex source code ---------
The PERL script renders above to:
------------- New doxygen code -------------
* \brief read raster history file
* This routine reads the history file for
* the raster file <b>name</b> in <b>mapset</b> into the <b>history</b>
* structure.
* A diagnostic message is printed and -1 is returned if there is an error
* reading the history file. Otherwise, 0 is returned.
* \param name
* \param mapset
* \param history
* \return int
int G_read_history (
------------- END New doxygen code ---------
If there are no objections, I would like to submit this to CVS.
TODO (will do, help welcome):
- polish the existing internal non-doxygen-style comments and
  merge with the new doxygen-style comments
- also migrate the other (relevant) general GRASS programmers Latex pages
  into file.dox files.
OUTCOME
We can render the entire programmer's manual from the
source code as GDAL and many other projects do. No more
efforts will be necessary to maintain a separate documents
which easily gets outdated. We are already following this idea in
GRASS 5.7.
Thanks to Paolo Armani from IRST for his magic PERL script!
On Wed, Sep 17, 2003 at 02:57:25PM +0200, Markus Neteler wrote:
Hi developers,
style.
OUTCOME
GRASS 5.7.
So, the first library documents are done for raster graphics lib.
You can see, how it works, here (temporary URL):
http://mpa.itc.it/markus/grass53/doxygenhtml/
(click on "raster Raster Graphics Library", the others are not done yet)
You can render these pages yourself by starting
./doxygen
in the main source directory. It does also PDF format (activate in
./Doxyfile if desired).
Step by step we'll move the intresting parts of the Latex docs into
this format. I have already all fixes changed, but will submit only
slowly after review to CVS.
If anyone is willing to participate, I can forward the changed
files for review. Also needed is the migration of the general
explanations from Latex to doxygen, such done for raster graphics lib
(chapter15.tex ->
http://mpa.itc.it/markus/grass53/doxygenhtml/rastergraphicslib.html
). This is basically a change from Latex to simple HTML.
